Home » Modeling » M2T (model-to-text transformation) » XSD adapter and imports(The OawXSDEcoreBuilder has to be called for every EPackage explicitly.)
XSD adapter and imports [message #496131] Sun, 08 November 2009 22:00 Go to next message
Marco  is currently offline Marco Friend
I think I have a similar problem as anubis stated in a message in the oAW forum in May: http://oaw-forum.itemis.de/forum/viewtopic.php?forum=1&s howtopic=1844 Unfortunately it was not answered.
I have 3 XSD which import each other. No matter which one I name in the workflow I get the following:
SEVERE: java.lang.RuntimeException: The OawXSDEcoreBuilder has to be called for every EPackage explicitly. Schema:XSDSchema 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test) Root:XSDSchema 'file:/.../foo/bar/root.xml.xsd' (null) XSDSchemas: 'file:/.../foo/bar/root.xml.xsd' (null), 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test)
java.lang.RuntimeException: java.lang.RuntimeException: The OawXSDEcoreBuilder has to be called for every EPackage explicitly. Schema:XSDSchema 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test) Root:XSDSchema 'file:/.../foo/bar/root.xml.xsd' (null) XSDSchemas: 'file:/.../foo/bar/root.xml.xsd' (null), 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test)
Any help is very appreciated.
br,
Marco
Re: XSD adapter and imports [message #497971 is a reply to message #496131] Fri, 13 November 2009 15:24 Go to previous messageGo to next message
Sorry for pushing this. But I do not find a solution myself.
Is there really no answer to this 1/2 year old issue.
I tried a lot. With having now the schema split in 2 XSD, both reference in schemaFile of the workflow, I still get the same:
WARNING: XSDSchema 'file:/.../foo/root.xml.xsd' has no namespace. Setting it to null
Nov 13, 2009 2:41:27 PM org.eclipse.xtend.typesystem.xsd.builder.OawXSDResource collectImportedSchemas
WARNING: Include /root.xml.xsd/XSDImport 'ns1.xsd' has not been resolved. XSDSchema 'file:/.../foo/root.xml.xsd' (null)
Nov 13, 2009 2:41:27 PM org.eclipse.xtend.typesystem.xsd.builder.XSDResolver locateSchema
INFO: Importing 'ns1.xsd' (http://www.example.org/test) from XSDSchema 'file:/.../foo/root.xml.xsd' (null)
Nov 13, 2009 2:41:27 PM org.eclipse.emf.mwe.internal.core.ast.util.VisitorCreator createBean
SEVERE: java.lang.RuntimeException: The OawXSDEcoreBuilder has to be called for every EPackage explicitly. Schema:XSDSchema 'file:/.../foo/ns1.xsd' (http://www.example.org/test) Root:XSDSchema 'file:/.../foo/root.xml.xsd' (null) XSDSchemas: 'file:/.../foo/root.xml.xsd' (null), 'file:/.../foo/ns1.xsd' (http://www.example.org/test)
br
m
Re: XSD adapter and imports [message #498032 is a reply to message #497971] Fri, 13 November 2009 18:03 Go to previous messageGo to next message
Moritz Eysholdt is currently offline Moritz EysholdtFriend
Hi Marco,
could you please create a bug-report at https://bugs.eclipse.org/bugs/
and attach the XSDs and the workflow I need to reproduce the problem?
cheers,
Moritz
> Setting it to null
> br
> m
Re: XSD adapter and imports [message #498086 is a reply to message #498032] Sat, 14 November 2009 11:36 Go to previous messageGo to next message
Hi Moritz,
Thank you for the answer.
When trying to drill into the problem I got stuck with much more basic issues. Please take a look a this thread. (project "attached")
br
Marco
Re: XSD adapter and imports [message #498094 is a reply to message #498086] Sat, 14 November 2009 12:29 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
hello Marco and Moritz,
i have filed following bug for the problem
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295157
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:XSD & Xpand (for xmt2test)
Next Topic:XPAND and XSD adapter
Current Time: Wed May 25 21:11:12 GMT 2022
Powered by FUDForum. Page generated in 0.03320 seconds
