Home » Language IDEs » PHP Development Tools (PDT) » Source Format uses tabs instead of spaces
Source Format uses tabs instead of spaces [message #496055] Sat, 07 November 2009 17:25 Go to next message
Artiom Neganov is currently offline Artiom NeganovFriend
On "General > Editors > Text editors" page I have "Insert spaces for tabls" checkbox checked so when I hit TAB in code - 4 spaces are inserted.
But code autoformat function (Ctrl+I) still insert tabs.
What I do wrong?
Re: Source Format uses tabs instead of spaces [message #496081 is a reply to message #496055] Sun, 08 November 2009 07:46 Go to previous messageGo to next message
Miha Vrhovnik is currently offline Miha VrhovnikFriend
I think It's a bug. The same happens if you select a block of code and press Tab key...
Re: Source Format uses tabs instead of spaces [message #1071316 is a reply to message #496055] Fri, 19 July 2013 20:16 Go to previous message
Eclipse hates me ! is currently offline Eclipse hates me !Friend
Edit: OK I'm an idiot, forget this
[Updated on: Sat, 20 July 2013 07:49]
Report message to a moderator
Previous Topic:How to track lines in Code while stepping / debugging
Next Topic:Eclipse PDT and XDebug 2.2.2
Current Time: Fri Jun 18 15:33:02 GMT 2021
Powered by FUDForum. Page generated in 0.02346 seconds
