Re: headless swtbot does not find testproject [message #496085 is a reply to message #496016] |
Sun, 08 November 2009 11:47 |
Sandor Szuecs Messages: 2 Registered: November 2009 |
Ketan Padegaonkar wrote on Fri, 06 November 2009 23:39 |
Did you delete the junit4 (or junit3) fragments supplied by swtbot as
described in the setup section of the wiki ? Do you have the
'org.eclipse.ant.optional.junit' fragment in your workspace ?
-- Ketan
I delete org.junit_3.8.2.* from plaugins folder and now it runs.
I thought it was not necessary, because on http://wiki.eclipse.org/SWTBot/Ant it was not mentioned. There is said only to use *.swtbot.*.junit4 (or 3).
I don't have 'org.eclipse.ant.optional.junit' on my workspace, do I need it?
Thanks and greets Sandor.
[Updated on: Sun, 08 November 2009 11:47] Report message to a moderator
Re: headless swtbot does not find testproject [message #500414 is a reply to message #496085] |
Thu, 26 November 2009 02:02 |
Originally posted by: qiyaoltc.gmail.com
Sandor Szuecs <sandor.szuecs@fu-berlin.de> writes:
>> -- Ketan
Sandor, I agree that we should add this in wiki page
Some people get the same trouble for several times.
Ketan, We may change Setup section like this,
Setup
Your folder structure should look like the following:
ECLIPSE_HOME
+ plugins
| - com.yourplugins
| - org.eclipse.swtbot.swt.finder
| - org.eclipse.swtbot.eclipse.finder
| - org.hamcrest (and other dependencies)
| - org.eclipse.swtbot.ant.optional.junit4 (or junit3, but not both) (from the Headless Testing Framework)
| - org.eclipse.swtbot.eclipse.junit4.headless (or junit3.headless, but not both) (from the Headless Testing Framework)
| - org.junit4 (or org.junit, but not both)
+ features
Do you agree on this change?
Best Regards
Yao Qi <qiyaoltc AT gmail DOT com> GNU/Linux Developer
http://duewayqi.googlepages.com/
They seem to have learned the habit of cowering before authority even when
not actually threatened. How very nice for authority. I decided not to
learn this particular lesson.
-- Richard Stallman
FUDForum. Page generated in 5.04270 seconds
