Re: Load a XMI file with xmlns:uml tag < 3.0.0 [message #495881 is a reply to message #495824] |
Fri, 06 November 2009 13:45 |
Ed Merks Messages: 33136 Registered: July 2009 |
--------------060002060803030107000608
When you say you don't find it, are you saying you didn't find the
section like this or it didn't work?
Programmatic Migration
In order to migrate models programmatically, some setup is required
in order to register mappings (already defined by UML). These
mappings will be used by the resource set during the loading stage
and will perform the necessary in-memory migration.
The example below demonstrates how one can migrate models with a
stand-alone application.
HTWTeam wrote:
> Vlad Varnica wrote on Thu, 05 November 2009 04:23
>> I don't understand the question :blush: Do you mean that you have a
>> xml coming from an UML model and you would like to create java code
>> or would you like to create graphical views ?
> Yes, I have a XMI that coming from an UML model. But I don't want to
> create java code or graphical views rather simple load the XMI model
> for count all classes in it.
> With an new xmi file (3.0.1 uml Tag) it works but older models could
> not be load.
> Ed Merks wrote on Thu, 05 November 2009 06:39
>> Maybe the details for "Programmatic Migration" here are similar:
>> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2.
>> 0_Migration_Guide/guide.html
> I have read it but don't find the methods for programmatic migration.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
section like this or it didn't work?<o:p> </o:p>
<blockquote>
<h2><!--[if gte vml 1]><v:shape id="_x0000_i1045" type="#_x0000_t75" alt=""
style='width:9.75pt;height:9.75pt'>
<v:imagedata src="" o:href="http://www.eclipse.org/modeling/mdt/images/new.gif"/>
</v:shape><![endif]--><span
style=""> </span>Programmatic
Migration</h2>
<p class="MsoNormal"><o:p> </o:p><br>
required in order to register mappings (already defined by UML).<span
style=""> </span>These mappings will be used by the resource
set during the loading stage and will perform the necessary in-memory
migration.</p>
<p class="MsoNormal"><o:p> </o:p>The example below demonstrates how
one can <span class="GramE">migrate</span> models with a stand-alone
application.<br>
</p>
</blockquote>
<p class="MsoNormal"><br>
</p>
<br>
<br>
HTWTeam wrote:
<blockquote cite="mid:hd0sf0$tac$1@build.eclipse.org" type="cite">Vlad
<br>
<blockquote type="cite">I don't understand the question :blush: Do
you mean that you have a xml coming from an UML model and you would
like to create java code or would you like to create graphical views ?
<br>
</blockquote>
<br>
<br>
<br>
<br>
not be load.
<br>
<br>
<br>
<blockquote type="cite">Maybe the details for "Programmatic
Migration" here are similar: <br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2">http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2</a>.
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------060002060803030107000608--
Ed Merks
FUDForum. Page generated in 0.02197 seconds
