Home » Modeling » M2T (model-to-text transformation) » Dealing with mixed types in XPAND for XSD(FeatureMaps?)
icon5.gif  Dealing with mixed types in XPAND for XSD [message #494831] Mon, 02 November 2009 20:43 Go to next message
Marco  is currently offline Marco Friend
I know I am missing detailed understanding of EMF and XSD but I just want to use it quickly.
I elaborated the following code in my XPAND:
«DEFINE element FOR ElementType-»
«IF expression.size > 0-»
(«EXPAND element FOR expression.get(0).argList.element.get(0)-»
 «expression.get(0).operation.mixed.get(0).toString().split('text=').get(1)-»
 «EXPAND element FOR expression.get(0).argList.element.get(1)-»
)«ENDIF-»
«IF type == "string"-»
«mixed.get(0).toString().split('text=').get(1)-»
«ENDIF-»
«IF constant.size > 0-»
«IF constant.get(0).type == "string"-»"«ENDIF-»
«constant.get(0).mixed.get(0).toString().split('text=').get(1)-»
«ENDIF-»
«ENDDEFINE»
It works but I have the strong feeling that there is a smarter way to handle the mixed types. Would you be so kind to give me a hint or even better show me how to phrase
«expression.get(0).operation.mixed.get(0).toString().split( 'text=').get(1)-»
correctly.
br,
Marco
Re: Dealing with mixed types in XPAND for XSD [message #495443 is a reply to message #494831] Wed, 04 November 2009 22:09 Go to previous messageGo to next message
Moritz Eysholdt is currently offline Moritz EysholdtFriend
Hi Marco,
how about
«expression.get(0).operation.mixed.text.get(0)-»
and, did you notice that you could also write
«EXPAND element FOREARCH expression.get(0).argList.element-»
instead of
in case you want to process all items from a list.
cheers,
Moritz
> )«ENDIF-»
> «ENDIF-»
> «constant.get(0).mixed.get(0).toString().split('text=').get (1)-»
> «ENDIF-»
> «ENDDEFINE»
> 'text=').get(1)-»
> correctly.
> br,
> Marco
Re: Dealing with mixed types in XPAND for XSD [message #495711 is a reply to message #495443] Thu, 05 November 2009 19:56 Go to previous message
Hi Moritz,
Thanks for the suggestion.
The auto-completion suggests text List[String] - XMLFeatureMap as option. But the workflow then produces an error:
EvaluationException : Couldn't find property 'text' for inner type EFeatureMapEntry'
I do not understand this.
br,
m
Previous Topic:GRAVE: Error in Component of type org.eclipse.xpand2.Generator:
Next Topic:[xpand] reference to metamodel not understood by generator
Current Time: Sun Nov 27 13:25:20 GMT 2022
Powered by FUDForum. Page generated in 0.02847 seconds
