Home » Eclipse Projects » EclipseLink » OneToMany, FetchType.LAZY, CascadeType.ALL: Fails to persist child
OneToMany, FetchType.LAZY, CascadeType.ALL: Fails to persist child [message #494526] |
Sat, 31 October 2009 07:14 |
Oliver Vesper Messages: 42 Registered: July 2009 |
Member |
I am having a simple test-case which fails and I wonder if I am doing
anything wrong or if it's a bug. I have two entites which look like this:
@Entity
public class Foo {
@Id
@GeneratedValue
private Long id;
@OneToMany(fetch = FetchType.LAZY, cascade = CascadeType.ALL)
private Collection<Bar> children = new ArrayList<Bar>();
@Entity
public class Bar {
@Id
@GeneratedValue
private Long id;
During my test I create a Foo instance, persist it and commit the
transaction. In the next step I lookup that entity, create a Bar
instance and add it to Foo's collection. Then I get a new transaction,
merge the Foo instance and commit the transaction. But the commit fails
with the following error:
[EL Warning]: UnitOfWork(7438914)--Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services -
2.0.0.v20091026-r5655): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.h2.jdbc.JdbcSQLException: NULL not allowed for
column CHILDREN_ID [90006-71]
Error Code: 90006
Call: INSERT IGNORE INTO FOO_BAR (children_ID, Foo_ID) VALUES (?, ?)
bind => [null, 1]
Query: DataModifyQuery(sql="INSERT IGNORE INTO FOO_BAR (children_ID, Foo_ID)
VALUES (?, ?)")
at
org.eclipse.persistence.exceptions.DatabaseException.sqlExce ption(DatabaseException.java:324)
If I change the FetchType from LAZY to EAGER, it works fine. Am I
missing something? I am using dynamic weaving and my entity-classes are
woven successfully. The EclipseLink version is 2.0.0.v20091026-r5655.
Thx in advance,
Oliver
Re: OneToMany, FetchType.LAZY, CascadeType.ALL: Fails to persist child [message #494799 is a reply to message #494765] |
Mon, 02 November 2009 16:53 |
Member |
> Seems quite odd, somehow the Bar id is null. The Bar should have been
> inserted before this, so what id was inserted?
> Could you include the full log, and the code you are using for the test.
Okay, so here's my Activator's start() code I am using through this test:
public void start(final BundleContext context) throws Exception {
try {
final Properties properties = new Properties();
properties.put(PersistenceUnitProperties.CLASSLOADER, this
.getClass().getClassLoader());
final EntityManagerFactory emf = Persistence
.createEntityManagerFactory("default", properties);
final EntityManager em = emf.createEntityManager();
EntityTransaction tx = em.getTransaction();
tx.begin();
final Foo foo = new Foo();
em.persist(foo);
tx.commit();
final Query query = em.createQuery("SELECT f FROM Foo f");
final List fooList = query.getResultList();
for (final Object object : fooList) {
Foo f = (Foo) object;
final Bar bar = new Bar();
f.getChildren().add(bar);
tx.begin();
f = em.merge(f);
tx.commit();
em.close();
emf.close();
} catch (final Throwable t) {
System.err.println(t.getMessage());
And this is the log-output:
osgi> Time to load bundles: 250
[EL Config]: ServerSession(6613606)--The access type for the persistent
class [class test.weaving.entities.Foo] is set to [FIELD].
[EL Config]: ServerSession(6613606)--The target entity (reference) class
for the one to many mapping element [field children] is being defaulted
to: class test.weaving.another.Bar.
class [class test.weaving.another.Bar] is set to [FIELD].
[EL Config]: ServerSession(6613606)--The alias name for the entity class
[class test.weaving.entities.Foo] is being defaulted to: Foo.
[EL Config]: ServerSession(6613606)--The table name for entity [class
test.weaving.entities.Foo] is being defaulted to: FOO.
[EL Config]: ServerSession(6613606)--The column name for element [field
id] is being defaulted to: ID.
x] is being defaulted to: X.
[class test.weaving.another.Bar] is being defaulted to: Bar.
test.weaving.another.Bar] is being defaulted to: BAR.
myDate] is being defaulted to: MYDATE.
[EL Config]: ServerSession(6613606)--The join table name for the many to
many mapping [field children] is being defaulted to: FOO_BAR.
[EL Config]: ServerSession(6613606)--The source primary key column name
for the many to many mapping [field children] is being defaulted to: ID.
[EL Config]: ServerSession(6613606)--The source foreign key column name
for the many to many mapping [field children] is being defaulted to: Foo_ID.
[EL Config]: ServerSession(6613606)--The target primary key column name
[EL Config]: ServerSession(6613606)--The target foreign key column name
children_ID.
Registering Service
{org.eclipse.persistence.jpa.equinox.weaving.IWeaver}={service.id=32}
test.weaving.entities.Foo woven
test.weaving.another.Bar woven
[EL Info]: ServerSession(6613606)--EclipseLink, version: Eclipse
Persistence Services - 2.0.0.v20091031-r5713
[EL Config]:
ServerSession(6613606)--Connection(17235092)--connecting(DatabaseLogin(
platform=>HSQLPlatform
user name=> "xyz"
datasource URL=> "jdbc:h2:c:/h2/default;create=true"
[EL Config]: ServerSession(6613606)--Connection(25383640)--Connected:
User: XYZ
Database: H2 Version: 1.0.71 (2008-04-25)
Driver: H2 JDBC Driver Version: 1.0.71 (2008-04-25)
[EL Config]:
ServerSession(6613606)--Connection(11800260)--connecting(DatabaseLogin(
user name=> "xyz"
[EL Config]: ServerSession(6613606)--Connection(20280994)--Connected:
User: XYZ
[EL Info]: ServerSession(6613606)--default login successful
[EL Fine]: ServerSession(6613606)--Connection(25383640)--CREATE TABLE
BAR (ID NUMERIC(19) IDENTITY NOT NULL, MYDATE TIMESTAMP, PRIMARY KEY (ID))
FOO (ID NUMERIC(19) IDENTITY NOT NULL, X VARCHAR(255), PRIMARY KEY (ID))
FOO_BAR (Foo_ID NUMERIC(19) NOT NULL, children_ID NUMERIC(19) NOT NULL,
PRIMARY KEY (Foo_ID, children_ID))
[EL Fine]: ClientSession(24478976)--Connection(20280994)--INSERT IGNORE INTO
FOO (X) VALUES (?)
bind => [null]
[EL Fine]: ClientSession(24478976)--Connection(20280994)--CALL IDENTITY()
[EL Fine]: ServerSession(6613606)--Connection(25383640)--SELECT ID, X
FROM FOO
BAR (MYDATE) VALUES (?)
bind => [null]
bind => [null, 1]
[EL Warning]: UnitOfWork(2161283)--Local Exception Stack:
2.0.0.v20091031-r5713): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 90006
bind => [null, 1]
VALUES (?, ?)")
at
org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:800)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeNoSelect(DatabaseAccessor.java:866)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:586)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:529)
at
org.eclipse.persistence.internal.sessions.AbstractSession.executeCall(AbstractSession.java:914)
at
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:205)
at
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:191)
at
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeNoSelectCall(DatasourceCallQueryMechanism.java:234)
at
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeNoSelect(DatasourceCallQueryMechanism.java:214)
at
org.eclipse.persistence.internal.queries.StatementQueryMechanism.executeNoSelect(StatementQueryMechanism.java:115)
at
org.eclipse.persistence.queries.DataModifyQuery.executeDatabaseQuery(DataModifyQuery.java:85)
at
org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:670)
at
org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:589)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2861)
at
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1225)
at
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1207)
at
org.eclipse.persistence.mappings.ManyToManyMapping.insertAddedObjectEntry(ManyToManyMapping.java:597)
at
org.eclipse.persistence.mappings.ManyToManyMapping.performDataModificationEvent(ManyToManyMapping.java:791)
at
org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsWithChangeSet(CommitManager.java:130)
at
org.eclipse.persistence.internal.sessions.AbstractSession.writeAllObjectsWithChangeSet(AbstractSession.java:3260)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1403)
at
org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:547)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1508)
at
org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:200)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1129)
at
org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:84)
at
org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:63)
at test.weaving.internal.Activator.start(Activator.java:47)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:353)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:370)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1068)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:554)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:461)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:246)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:442)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
Caused by: org.h2.jdbc.JdbcSQLException: NULL not allowed for column
at org.h2.message.Message.getSQLException(Message.java:92)
at org.h2.message.Message.getSQLException(Message.java:96)
at org.h2.message.Message.getSQLException(Message.java:74)
at org.h2.table.Column.validateConvertUpdateSequence(Column.java:231)
at org.h2.table.Table.validateConvertUpdateSequence(Table.java:470)
at org.h2.command.dml.Insert.update(Insert.java:92)
at org.h2.command.CommandContainer.update(CommandContainer.java:69)
at org.h2.command.Command.executeUpdate(Command.java:198)
at
org.h2.jdbc.JdbcPreparedStatement.executeUpdateInternal(JdbcPreparedStatement.java:131)
at
org.h2.jdbc.JdbcPreparedStatement.executeUpdate(JdbcPreparedStatement.java:120)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:791)
... 40 more
Error Code: 90006
bind => [null, 1]
VALUES (?, ?)")
> It probably has something to do with your merge, that is somehow
> corrupting the object clones. Why are you using merge? merge() is
> meant for when an object get serialized, are you serializing your
objects?
I want to merge my entity's state into the persistence layer which
should result in having the Bar object be persisted and have the Foo
object be the Bar's owner. To achieve this I have to use the merge() as
far as I know.
-Oliver
Current Time: Thu Mar 28 21:53:24 GMT 2024
Powered by FUDForum. Page generated in 0.02983 seconds
