Home » Modeling » M2T (model-to-text transformation) » [XPAND] accessing <<FILE ...>> from Java(Need help on how to access a <<FILE>> created in XPAND from Java)
[XPAND] accessing <<FILE ...>> from Java [message #493741] Tue, 27 October 2009 18:20 Go to next message
Roberto Salama is currently offline Roberto SalamaFriend
Hello:
I have the following .xpt file:
«IMPORT entityDsl»
«EXTENSION templates::Extensions»
«DEFINE main FOR Model-»
«FILE "output.txt"-»
«EXPAND Instance FOREACH this.instances-»
«ENDFILE-»
«ENDDEFINE»
«DEFINE Instance FOR Instance»
«createInstance(this)»
«ENDDEFINE»
The method creatInstance(this) is mapped to a java call in the .ext file:
Void createInstance(Instance i) :
JAVA helper.EntityHandler.createInstance(com.ms.entityDsl.Instanc e);
How can I access the FILE created in the .xpt file from inside the createInstance() java call?
Thanks!
roberto
Re: [XPAND] accessing <<FILE ...>> from Java [message #493749 is a reply to message #493741] Tue, 27 October 2009 19:46 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hello roberto,
afaik this is not possible. what is the usecase you need this feature for?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [XPAND] accessing <<FILE ...>> from Java [message #493903 is a reply to message #493749] Wed, 28 October 2009 13:03 Go to previous messageGo to next message
Thanks for your reply.
While writing XPAND templates, I find myself resorting to Java mainly to leverage Maps which I don't know how to access from XPAND directly.
My use case, in this case, is to manipulate an Entity in java using a couple of maps. So an Entity contains properties, entities are created (ie x = new Foo()) then values are set (ie, x.name = "Pluto"; x.age = 3). In traversing the AST with XPAND, I use a Map to store key value relationships which I then need to serialize. This is just a toy language not a real world use case, but I can see that not being able to use (or not knowing how to use) a Map XPAND requires me to dive into Java. Even though I am serializing, I can see the need to write back to the <<FILE>> from Java.
thanks.
Re: [XPAND] accessing <<FILE ...>> from Java [message #493905 is a reply to message #493903] Wed, 28 October 2009 13:11 Go to previous messageGo to next message
hi,
if i unserstand your problem you create a String with Java and want to wirte this into the Xpand file. So why don't let the extension return the string.
Re: [XPAND] accessing <<FILE ...>> from Java [message #493910 is a reply to message #493905] Wed, 28 October 2009 13:30 Go to previous messageGo to next message
Sorry for the typos in my previous posts. my phases might have been a bit misunderstandable:
here an example who to write code from a Java Extension into a file using the xpand / xtend / java - queue:
Java:
public class MyJavaExtensions {
   public String myXtendFunction(Parameter param) {
       String result = "";
      // do some calculation
return result;
Xtend
String myXtendFuntion(Parameter param):
    JAVA path.MyJavaExtensions.myXtendFunction(oath.Parameter);
Xpand
<< FILE "test.txt">>
<<myXtendFuntion(param)>>
<<ENDFILE>>
Re: [XPAND] accessing <<FILE ...>> from Java [message #494100 is a reply to message #493903] Thu, 29 October 2009 08:47 Go to previous message
Karsten Thoms is currently offline Karsten ThomsFriend
If you just want to assign dynamic values to your Entity instances, use Xtend stdlib ElementProperties extensions. You will find a reference in the docs. In your Java code you could call ElementPropertiesExtensions.get/setProperty().
Coming back to your initial request: You could access the FILE statement from Java with some hacks: You'd need to implement a Callback that is registered to the Generator component. This gets informed on any statement evaluated. Then recognize opening FILE statements and store a handle to this instance in a ThreadLocal. This ThreadLocal must be made accessible from your Java method that needs the File statement. Since this is a real hack you see that's not a common use case.
Best wishes,
~Karsten
Need professional support for Xtext, EMF, Eclipse IDE?
Go to: http://devhub.karakun.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
Previous Topic:[MWE]: NPE in WorkflowRunner#prepare()
Next Topic:Use case specification and transformation
Current Time: Wed Nov 30 22:18:08 GMT 2022
Powered by FUDForum. Page generated in 0.02630 seconds
