Re: Connect to the OSEE Application-Server [message #493874 is a reply to message #493492] |
Wed, 28 October 2009 10:48   |
HTWTeam  Messages: 6 Registered: October 2009 |
Hi Nirmal,
thank you for your reply.
I'm sorry for my inaccurate question. We downloaded and installed the all-in-one package for 0.7 and could successfully install and use OSEE with it, but that's not where our problem lies.
We want to program our very own OSEE client which uses the OSEE API to communicate and interact with the OSEE Application Server running in the background, offering a web service which allows OSEE to be integrated into some other automated software engineering tool framework. This framework interacts with the SE tools via web service events, so we want to write an adapter that translates those events into OSEE application server API calls.
Alas, there seems to be no documentation on the API and the documentation covering the architecture seems to be bit dated, as we were not able to find some of the methods in the sequence diagrams.
We tried to write a small test program which connects to a local running OSEE application server, but we couldn't get it to work and are a bit helpless right now.
So if anyone knows something about the API or how to program a client for OSEE, please let us know.
[Updated on: Wed, 28 October 2009 12:44] Report message to a moderator
Re: Connect to the OSEE Application-Server [message #495223 is a reply to message #493874] |
Wed, 04 November 2009 09:25  |
Nirmal Sasidharan Messages: 120 Registered: July 2009 Location: Germany |
I doubt if you would find any documentation regarding this. The current OSEE client implementation would be the best example you could look into. Needless to say, try debugging it (I am sure you would had done this already)
All the best,
Nirmal
Re: Connect to the OSEE Application-Server [message #576041 is a reply to message #575986] |
All the best,
Nirmal
FUDForum. Page generated in 0.03384 seconds
