Home » Newcomers » Newcomers » Hang on Starting jboss(look like eclipse can't recognize the full start of jboss.)
Hang on Starting jboss [message #493366] |
Sun, 25 October 2009 09:56 |
Gianluca Messages: 2 Registered: October 2009 |
Hi all, i'm new to Eclipse, and i'm trying to learn it.
I've succesful installed my projects and deployed on tomcat
Then i wanted to learn something about ejb ,and succesfull installed Jboss 5.1.0.GA.
I Can deploy my projects and even access them when Jboss is Started, but Eclipse can't recognize the full start of jboss and mantain active the "Starting jboss" progress active.
So when eclipse reach the configured timeout for start on Jboss it kill the server, and also putting a really high timeout i can't do some simple task like republish a project and so on.
I've done something wrong ? or there's a way to avoid this problem or a workaround ?
Thanks in advance for any help
P.S. here's my jboss start log
10:45:23,357 INFO [ServerImpl] Starting JBoss (Microcontainer)...
10:45:23,358 INFO [ServerImpl] Release ID: JBoss [The Oracle] 5.1.0.GA (build: SVNTag=JBoss_5_1_0_GA date=200905221634)
10:45:23,358 INFO [ServerImpl] Bootstrap URL: null
10:45:23,358 INFO [ServerImpl] Home Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA
10:45:23,359 INFO [ServerImpl] Home URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/
10:45:23,359 INFO [ServerImpl] Library URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/lib/
10:45:23,359 INFO [ServerImpl] Patch URL: null
10:45:23,359 INFO [ServerImpl] Common Base URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/common/
10:45:23,360 INFO [ServerImpl] Common Library URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/common/lib/
10:45:23,360 INFO [ServerImpl] Server Name: default
10:45:23,360 INFO [ServerImpl] Server Base Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server
10:45:23,360 INFO [ServerImpl] Server Base URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/
10:45:23,361 INFO [ServerImpl] Server Config URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/conf/
10:45:23,361 INFO [ServerImpl] Server Home Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default
10:45:23,361 INFO [ServerImpl] Server Home URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/
10:45:23,361 INFO [ServerImpl] Server Data Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default\data
10:45:23,361 INFO [ServerImpl] Server Library URL: file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/lib/
10:45:23,361 INFO [ServerImpl] Server Log Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default\log
10:45:23,362 INFO [ServerImpl] Server Native Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default\tmp\native
10:45:23,362 INFO [ServerImpl] Server Temp Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default\tmp
10:45:23,362 INFO [ServerImpl] Server Temp Deploy Dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default\tmp\deploy
10:45:24,129 INFO [ServerImpl] Starting Microcontainer, bootstrapURL=file:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/conf/bootstrap.xml
10:45:25,033 INFO [VFSCacheFactory] Initializing VFSCache [org.jboss.virtual.plugins.cache.CombinedVFSCache]
10:45:25,038 INFO [VFSCacheFactory] Using VFSCache [CombinedVFSCache[real-cache: null]]
10:45:25,425 INFO [CopyMechanism] VFS temp dir: C:\jboss-5.1.0.GA-jdk6\jboss-5.1.0.GA\server\default\tmp
10:45:25,476 INFO [ZipEntryContext] VFS force nested jars copy-mode is enabled.
10:45:26,787 INFO [ServerInfo] Java version: 1.6.0_12,Sun Microsystems Inc.
10:45:26,787 INFO [ServerInfo] Java Runtime: Java(TM) SE Runtime Environment (build 1.6.0_12-b04)
10:45:26,787 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM 11.2-b01,Sun Microsystems Inc.
10:45:26,787 INFO [ServerInfo] OS-System: Windows Vista 6.0,x86
10:45:26,788 INFO [ServerInfo] VM arguments: -agentlib:jdwp=transport=dt_socket,suspend=y,address=localhost:51773 -Dprogram.name=run.bat -Xms128m -Xmx512m -XX:MaxPermSize=256m -Dfile.encoding=Cp1252
10:45:26,853 INFO [JMXKernel] Legacy JMX core initialized
10:45:29,002 INFO [ProfileServiceBootstrap] Loading profile: ProfileKey@1a63e10[domain=default, server=default, name=default]
10:45:31,287 INFO [WebService] Using RMI server codebase: http://127.0.0.1:8083/
10:45:39,354 INFO [NativeServerConfig] JBoss Web Services - Stack Native Core
10:45:39,354 INFO [NativeServerConfig] 3.1.2.GA
10:45:40,113 INFO [AttributeCallbackItem] Owner callback not implemented.
10:45:42,061 INFO [LogNotificationListener] Adding notification listener for logging mbean "jboss.system:service=Logging,type=Log4jService" to server org.jboss.mx.server.MBeanServerImpl@d2c8c0[ defaultDomain='jboss' ]
10:46:04,620 INFO [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@16942920{vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/EjbTest.jar/}
10:46:04,622 INFO [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@16942920{vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/EjbTest.jar/}
10:46:04,623 INFO [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@19403343{vfsfile:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/profileservice-secured.jar/}
10:46:09,017 INFO [JMXConnectorServerService] JMX Connector server: service:jmx:rmi://127.0.0.1/jndi/rmi://127.0.0.1:1090/jmxconnector
10:46:09,291 INFO [MailService] Mail Service bound to java:/Mail
10:46:13,805 WARN [JBossASSecurityMetadataStore] WARNING! POTENTIAL SECURITY RISK. It has been detected that the MessageSucker component which sucks messages from one node to another has not had its password changed from the installation default. Please see the JBoss Messaging user guide for instructions on how to do this.
10:46:13,849 WARN [AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
10:46:13,975 WARN [AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
10:46:14,077 INFO [TransactionManagerService] JBossTS Transaction Service (JTA version - tag:JBOSSTS_4_6_1_GA) - JBoss Inc.
10:46:14,077 INFO [TransactionManagerService] Setting up property manager MBean and JMX layer
10:46:14,729 INFO [TransactionManagerService] Initializing recovery manager
10:46:15,050 INFO [TransactionManagerService] Recovery manager configured
10:46:15,051 INFO [TransactionManagerService] Binding TransactionManager JNDI Reference
10:46:15,103 INFO [TransactionManagerService] Starting transaction recovery manager
10:46:16,420 INFO [AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre6\bin;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\MySQL\MySQL Server 5.0\bin;C:\PROGRA~1\ULTRAE~1;C:\Program Files\TortoiseSVN\bin;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\CollabNet Subversion
10:46:16,692 INFO [Http11Protocol] Initializing Coyote HTTP/1.1 on http-127.0.0.1-8080
10:46:16,706 INFO [AjpProtocol] Initializing Coyote AJP/1.3 on ajp-127.0.0.1-8009
10:46:16,831 INFO [StandardService] Starting service jboss.web
10:46:16,844 INFO [StandardEngine] Starting Servlet Engine: JBoss Web/2.1.3.GA
10:46:17,053 INFO [Catalina] Server startup in 346 ms
10:46:17,171 INFO [TomcatDeployment] deploy, ctxPath=/web-console
10:46:20,349 INFO [TomcatDeployment] deploy, ctxPath=/invoker
10:46:20,545 INFO [TomcatDeployment] deploy, ctxPath=/jbossws
10:46:20,769 INFO [RARDeployment] Required license terms exist, view vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/jboss-local-jdbc.rar/META-INF/ra.xml
10:46:20,791 INFO [RARDeployment] Required license terms exist, view vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/jboss-xa-jdbc.rar/META-INF/ra.xml
10:46:20,815 INFO [RARDeployment] Required license terms exist, view vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/jms-ra.rar/META-INF/ra.xml
10:46:20,837 INFO [RARDeployment] Required license terms exist, view vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/mail-ra.rar/META-INF/ra.xml
10:46:20,870 INFO [RARDeployment] Required license terms exist, view vfszip:/C:/jboss-5.1.0.GA-jdk6/jboss-5.1.0.GA/server/default/deploy/quartz-ra.rar/META-INF/ra.xml
10:46:21,068 INFO [SimpleThreadPool] Job execution threads will use class loader of thread: main
10:46:21,129 INFO [QuartzScheduler] Quartz Scheduler v.1.5.2 created.
10:46:21,133 INFO [RAMJobStore] RAMJobStore initialized.
10:46:21,134 INFO [StdSchedulerFactory] Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties'
10:46:21,134 INFO [StdSchedulerFactory] Quartz scheduler version: 1.5.2
10:46:21,134 INFO [QuartzScheduler] Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.
10:46:21,517 INFO [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=ejbTestDS' to JNDI name 'java:ejbTestDS'
10:46:22,871 INFO [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name 'java:DefaultDS'
10:46:24,274 INFO [ServerPeer] JBoss Messaging 1.4.3.GA server [0] started
10:46:24,475 INFO [QueueService] Queue[/queue/ExpiryQueue] started, fullSize=200000, pageSize=2000, downCacheSize=2000
10:46:24,573 INFO [ConnectionFactory] Connector bisocket://127.0.0.1:4457 has leasing enabled, lease period 10000 milliseconds
10:46:24,573 INFO [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@598a3a started
10:46:24,574 INFO [ConnectionFactoryJNDIMapper] supportsFailover attribute is true on connection factory: jboss.messaging.connectionfactory:service=ClusteredConnectionFactory but post office is non clustered. So connection factory will *not* support failover
10:46:24,574 INFO [ConnectionFactoryJNDIMapper] supportsLoadBalancing attribute is true on connection factory: jboss.messaging.connectionfactory:service=ClusteredConnectionFactory but post office is non clustered. So connection factory will *not* support load balancing
10:46:24,582 INFO [ConnectionFactory] Connector bisocket://127.0.0.1:4457 has leasing enabled, lease period 10000 milliseconds
10:46:24,582 INFO [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@17b9ecd started
10:46:24,584 INFO [QueueService] Queue[/queue/DLQ] started, fullSize=200000, pageSize=2000, downCacheSize=2000
10:46:24,586 INFO [ConnectionFactory] Connector bisocket://127.0.0.1:4457 has leasing enabled, lease period 10000 milliseconds
10:46:24,586 INFO [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@50823f started
10:46:24,930 INFO [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name 'java:JmsXA'
10:46:26,392 INFO [JBossASKernel] Created KernelDeployment for: EjbTest.jar
10:46:26,413 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=EjbTest.jar,name=NumberServiceBean,service=EJB3
10:46:26,413 INFO [JBossASKernel] with dependencies:
10:46:26,414 INFO [JBossASKernel] and demands:
10:46:26,414 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
10:46:26,414 INFO [JBossASKernel] and supplies:
10:46:26,414 INFO [JBossASKernel] Class:org.tutorial.bean.remote.NumberService
10:46:26,414 INFO [JBossASKernel] jndi:NumberCreator
10:46:26,414 INFO [JBossASKernel] jndi:NumberServiceBean/remote-org.tutorial.bean.remote.NumberService
10:46:26,415 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=EjbTest.jar,name=NumberServiceBean,service=EJB3) to KernelDeployment of: EjbTest.jar
10:46:26,416 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=EjbTest.jar,name=UsertestFacadeBean,service=EJB3
10:46:26,416 INFO [JBossASKernel] with dependencies:
10:46:26,416 INFO [JBossASKernel] and demands:
10:46:26,417 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
10:46:26,417 INFO [JBossASKernel] persistence.unit:unitName=#EjbTestPU
10:46:26,417 INFO [JBossASKernel] and supplies:
10:46:26,417 INFO [JBossASKernel] jndi:UsertestFacade
10:46:26,417 INFO [JBossASKernel] Class:org.tutorial.jpa.UsertestFacade
10:46:26,417 INFO [JBossASKernel] jndi:UsertestFacadeBean/remote-org.tutorial.jpa.UsertestFacade
10:46:26,417 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=EjbTest.jar,name=UsertestFacadeBean,service=EJB3) to KernelDeployment of: EjbTest.jar
10:46:26,446 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@19085c4{name=jboss.j2ee:jar=EjbTest.jar,name=NumberServiceBean,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
10:46:26,446 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@247827{name=jboss.j2ee:jar=EjbTest.jar,name=UsertestFacadeBean,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
10:46:26,675 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=EjbTest.jar,name=NumberServiceBean,service=EJB3
10:46:26,710 INFO [EJBContainer] STARTED EJB: org.tutorial.bean.NumberServiceBean ejbName: NumberServiceBean
10:46:26,873 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
NumberCreator - EJB3.x Default Remote Business Interface
NumberServiceBean/remote-org.tutorial.bean.remote.NumberService - EJB3.x Remote Business Interface
10:46:26,951 INFO [PersistenceUnitDeployment] Starting persistence unit persistence.unit:unitName=#EjbTestPU
10:46:27,124 INFO [Version] Hibernate Annotations 3.4.0.GA
10:46:27,168 INFO [Environment] Hibernate 3.3.1.GA
10:46:27,194 INFO [Environment] hibernate.properties not found
10:46:27,202 INFO [Environment] Bytecode provider name : javassist
10:46:27,217 INFO [Environment] using JDK 1.4 java.sql.Timestamp handling
10:46:27,476 INFO [Version] Hibernate Commons Annotations 3.1.0.GA
10:46:27,487 INFO [Version] Hibernate EntityManager 3.4.0.GA
10:46:27,577 INFO [Ejb3Configuration] Processing PersistenceUnitInfo [
10:46:27,625 WARN [Ejb3Configuration] Persistence provider caller does not implement the EJB3 spec correctly. PersistenceUnitInfo.getNewTempClassLoader() is null.
10:46:29,125 INFO [AnnotationBinder] Binding entity from annotated class: org.tutorial.jpa.impl.Usertest
10:46:29,370 INFO [EntityBinder] Bind entity org.tutorial.jpa.impl.Usertest on table usertest
10:46:29,625 INFO [Version] Hibernate Validator 3.1.0.GA
10:46:29,941 INFO [HibernateSearchEventListenerRegister] Unable to find org.hibernate.search.event.FullTextIndexEventListener on the classpath. Hibernate Search is not enabled.
10:46:30,301 INFO [ConnectionProviderFactory] Initializing connection provider: org.hibernate.ejb.connection.InjectedDataSourceConnectionProvider
10:46:30,316 INFO [InjectedDataSourceConnectionProvider] Using provided datasource
10:46:30,781 INFO [SettingsFactory] RDBMS: MySQL, version: 5.0.18-nt
10:46:30,782 INFO [SettingsFactory] JDBC driver: MySQL-AB JDBC Driver, version: mysql-connector-java-5.1.10 ( Revision: ${svn.Revision} )
10:46:30,837 INFO [Dialect] Using dialect: org.hibernate.dialect.MySQLDialect
10:46:30,850 INFO [TransactionFactoryFactory] Transaction strategy: org.hibernate.ejb.transaction.JoinableCMTTransactionFactory
10:46:30,858 INFO [TransactionManagerLookupFactory] instantiating TransactionManagerLookup: org.hibernate.transaction.JBossTransactionManagerLookup
10:46:30,866 INFO [TransactionManagerLookupFactory] instantiated TransactionManagerLookup
10:46:30,866 INFO [SettingsFactory] Automatic flush during beforeCompletion(): disabled
10:46:30,866 INFO [SettingsFactory] Automatic session close at end of transaction: disabled
10:46:30,866 INFO [SettingsFactory] JDBC batch size: 15
10:46:30,866 INFO [SettingsFactory] JDBC batch updates for versioned data: disabled
10:46:30,869 INFO [SettingsFactory] Scrollable result sets: enabled
10:46:30,869 INFO [SettingsFactory] JDBC3 getGeneratedKeys(): enabled
10:46:30,869 INFO [SettingsFactory] Connection release mode: auto
10:46:30,872 INFO [SettingsFactory] Maximum outer join fetch depth: 2
10:46:30,872 INFO [SettingsFactory] Default batch fetch size: 1
10:46:30,872 INFO [SettingsFactory] Generate SQL with comments: disabled
10:46:30,873 INFO [SettingsFactory] Order SQL updates by primary key: disabled
10:46:30,873 INFO [SettingsFactory] Order SQL inserts for batching: disabled
10:46:30,873 INFO [SettingsFactory] Query translator: org.hibernate.hql.ast.ASTQueryTranslatorFactory
10:46:30,883 INFO [ASTQueryTranslatorFactory] Using ASTQueryTranslatorFactory
10:46:30,883 INFO [SettingsFactory] Query language substitutions: {}
10:46:30,883 INFO [SettingsFactory] JPA-QL strict compliance: enabled
10:46:30,883 INFO [SettingsFactory] Second-level cache: enabled
10:46:30,883 INFO [SettingsFactory] Query cache: disabled
10:46:30,908 INFO [SettingsFactory] Cache region factory : org.hibernate.cache.impl.bridge.RegionFactoryCacheProviderBridge
10:46:30,908 INFO [RegionFactoryCacheProviderBridge] Cache provider: org.hibernate.cache.HashtableCacheProvider
10:46:30,917 INFO [SettingsFactory] Optimize cache for minimal puts: disabled
10:46:30,917 INFO [SettingsFactory] Cache region prefix: persistence.unit:unitName=#EjbTestPU
10:46:30,917 INFO [SettingsFactory] Structured second-level cache entries: disabled
10:46:30,944 INFO [SettingsFactory] Statistics: disabled
10:46:30,944 INFO [SettingsFactory] Deleted entity synthetic identifier rollback: disabled
10:46:30,947 INFO [SettingsFactory] Default entity-mode: pojo
10:46:30,948 INFO [SettingsFactory] Named query checking : enabled
10:46:31,091 INFO [SessionFactoryImpl] building session factory
10:46:31,602 INFO [SessionFactoryObjectFactory] Factory name: persistence.unit:unitName=#EjbTestPU
10:46:31,606 INFO [NamingHelper] JNDI InitialContext properties:{java.naming.factory.initial=org.jnp.interfaces.NamingContextFactory, java.naming.factory.url.pkgs=org.jboss.naming:org.jnp.interfaces}
10:46:31,658 INFO [SessionFactoryObjectFactory] Bound factory to JNDI name: persistence.unit:unitName=#EjbTestPU
10:46:31,658 WARN [SessionFactoryObjectFactory] InitialContext did not implement EventContext
10:46:31,658 INFO [NamingHelper] JNDI InitialContext properties:{java.naming.factory.initial=org.jnp.interfaces.NamingContextFactory, java.naming.factory.url.pkgs=org.jboss.naming:org.jnp.interfaces}
10:46:31,722 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=EjbTest.jar,name=UsertestFacadeBean,service=EJB3
10:46:31,758 INFO [EJBContainer] STARTED EJB: org.tutorial.jpa.impl.UsertestFacadeBean ejbName: UsertestFacadeBean
10:46:31,770 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
UsertestFacade - EJB3.x Default Remote Business Interface
UsertestFacadeBean/remote-org.tutorial.jpa.UsertestFacade - EJB3.x Remote Business Interface
10:46:31,984 INFO [JBossASKernel] Created KernelDeployment for: profileservice-secured.jar
10:46:31,984 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3
10:46:31,984 INFO [JBossASKernel] with dependencies:
10:46:31,984 INFO [JBossASKernel] and demands:
10:46:31,984 INFO [JBossASKernel] jndi:SecureManagementView/remote-org.jboss.deployers.spi.management.ManagementView
10:46:31,984 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
10:46:31,984 INFO [JBossASKernel] and supplies:
10:46:31,984 INFO [JBossASKernel] Class:org.jboss.profileservice.spi.ProfileService
10:46:31,984 INFO [JBossASKernel] jndi:SecureProfileService/remote
10:46:31,984 INFO [JBossASKernel] jndi:SecureProfileService/remote-org.jboss.profileservice.spi.ProfileService
10:46:31,984 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3) to KernelDeployment of: profileservice-secured.jar
10:46:31,985 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3
10:46:31,985 INFO [JBossASKernel] with dependencies:
10:46:31,985 INFO [JBossASKernel] and demands:
10:46:31,985 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
10:46:31,986 INFO [JBossASKernel] and supplies:
10:46:31,986 INFO [JBossASKernel] jndi:SecureDeploymentManager/remote-org.jboss.deployers.spi.management.deploy.DeploymentManager
10:46:31,986 INFO [JBossASKernel] Class:org.jboss.deployers.spi.management.deploy.DeploymentManager
10:46:31,986 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3) to KernelDeployment of: profileservice-secured.jar
10:46:31,986 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3
10:46:31,986 INFO [JBossASKernel] with dependencies:
10:46:31,987 INFO [JBossASKernel] and demands:
10:46:31,987 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
10:46:31,987 INFO [JBossASKernel] and supplies:
10:46:31,987 INFO [JBossASKernel] jndi:SecureManagementView/remote-org.jboss.deployers.spi.management.ManagementView
10:46:31,987 INFO [JBossASKernel] Class:org.jboss.deployers.spi.management.ManagementView
10:46:31,987 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3) to KernelDeployment of: profileservice-secured.jar
10:46:31,988 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@1655ccd{name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
10:46:31,988 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@93e638{name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
10:46:31,988 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@10b64a{name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
10:46:32,061 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3
10:46:32,062 INFO [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureDeploymentManager ejbName: SecureDeploymentManager
10:46:32,110 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
SecureDeploymentManager/remote - EJB3.x Default Remote Business Interface
SecureDeploymentManager/remote-org.jboss.deployers.spi.management.deploy.DeploymentManager - EJB3.x Remote Business Interface
10:46:32,158 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3
10:46:32,160 INFO [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureManagementView ejbName: SecureManagementView
10:46:32,176 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
SecureManagementView/remote - EJB3.x Default Remote Business Interface
SecureManagementView/remote-org.jboss.deployers.spi.management.ManagementView - EJB3.x Remote Business Interface
10:46:32,238 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3
10:46:32,261 INFO [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureProfileServiceBean ejbName: SecureProfileService
10:46:32,273 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
SecureProfileService/remote - EJB3.x Default Remote Business Interface
SecureProfileService/remote-org.jboss.profileservice.spi.ProfileService - EJB3.x Remote Business Interface
10:46:32,569 INFO [TomcatDeployment] deploy, ctxPath=/admin-console
10:46:32,955 INFO [config] Initializing Mojarra (1.2_12-b01-FCS) for context '/admin-console'
10:46:42,051 INFO [TomcatDeployment] deploy, ctxPath=/
10:46:42,179 INFO [TomcatDeployment] deploy, ctxPath=/jmx-console
10:46:42,647 INFO [TomcatDeployment] deploy, ctxPath=/jsfTest01
10:46:42,968 INFO [config] Initializing Mojarra (1.2_12-b01-FCS) for context '/jsfTest01'
10:46:46,551 INFO [Http11Protocol] Starting Coyote HTTP/1.1 on http-127.0.0.1-8080
10:46:46,595 INFO [AjpProtocol] Starting Coyote AJP/1.3 on ajp-127.0.0.1-8009
10:46:46,616 INFO [ServerImpl] JBoss (Microcontainer) [5.1.0.GA (build: SVNTag=JBoss_5_1_0_GA date=200905221634)] Started in 1m:23s:251ms
Current Time: Fri Apr 19 08:06:12 GMT 2024
Powered by FUDForum. Page generated in 0.03236 seconds
