Home » Archived » Test and Performance Tools Platform (TPTP) » java.lang.NullPointerException(Cannot fetch data collectors)
java.lang.NullPointerException [message #492642] Wed, 21 October 2009 08:48 Go to next message
Mikael Petterson is currently offline Mikael PettersonFriend
I changed to using jdk 1.5 since I read that support for 1.4 seems to be removed ( that might be the reson for my problems in previous post).
I am still doing the profiling locally.
GUI: Fetching children of data collector ... 0%
It hangs there forever and log is filled with ( see below).
br,
//miakel
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@b3f220" java.lang.NullPointerException
at org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.versionIsAtLeast(AgentControllerDescriptor.java:67)
at org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.isVersionAtLeast(AgentControllerDescriptor.java:194)
at org.eclipse.hyades.execution.local.file.FileManagerFactory$3 .run(FileManagerFactory.java:413)
at org.eclipse.hyades.execution.core.task.ReusableThread.run(Re usableThread.java:131)
at java.lang.Thread.run(Thread.java:619)
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@337ff4" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@d5a66a" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@12ab673" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@10f144e" java.lang.NullPointerException
Exception in thread "org.eclipse.hyades.execution.core.task.ReusableThread@985bf9" java.lang.NullPointerException
Re: java.lang.NullPointerException [message #495057 is a reply to message #492642] Tue, 03 November 2009 16:27 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
I could not reproduce the problem you reported here.
Did you change the jdk version of the Eclipse workbench or the Agent
Controller setting under Preferences.
Could you open a defect on TPTP bugzilla system and list the step and setup
you have to help the developer reproduce the problem and investigate?
Eugene
"Mikael Petterson" <mikaelpetterson@hotmail.com> wrote in message
news:hbmhth$69a$1@build.eclipse.org...
> br,
> //miakel
> Exception in thread
> "mailto:org.eclipse.hyades.execution.core.task.ReusableThread@b3f220"
> Exception in thread
> "mailto:org.eclipse.hyades.execution.core.task.ReusableThread@337ff4"
> Exception in thread
> "mailto:org.eclipse.hyades.execution.core.task.ReusableThread@d5a66a"
> Exception in thread
> "mailto:org.eclipse.hyades.execution.core.task.ReusableThread@12ab673"
> Exception in thread
> "mailto:org.eclipse.hyades.execution.core.task.ReusableThread@10f144e"
> Exception in thread
> "mailto:org.eclipse.hyades.execution.core.task.ReusableThread@985bf9"
Re: java.lang.NullPointerException [message #555517 is a reply to message #492642] Thu, 26 August 2010 21:59 Go to previous messageGo to next message
Matt  is currently offline Matt Friend
I installed TPTP 4.6.2 today. It worked initially without problems, and then started hanging at the Monitor window. The exceptions I saw in the logs were same as described above.
The problem turned out to be simple. Integrated Agent Controller runs on port 10002 by default. Somehow, though I shut down Eclipse, Agent Controller didn't die, it was still running, listening on 10002. Try this to see if it's running
telnet localhost 10002
Once I killed that process, I started up Eclipse, and TPTP worked again.
TPTP is great. Suggestions to TPTP guys:
1. There appear to be cases where Eclipse can exit, but the Controller lingers on. Should be fixed.
2. If there was anything like "TPTP controller is unable to establish connection on port 10002" in the logs, I would've figured this out in 5 minutes instead of half a day.
-Matt
Re: java.lang.NullPointerException [message #555520 is a reply to message #495057] Thu, 26 August 2010 22:02 Go to previous message
-Matt
Previous Topic:TPTP 4.5 Profiling crash (Sun, Vista)
Next Topic:Java Object reference analysis views
Current Time: Thu Oct 01 14:03:56 GMT 2020
Powered by FUDForum. Page generated in 0.01767 seconds
