Re: Delta pack failed on 3.5.1 [message #495574 is a reply to message #493024] |
Thu, 05 November 2009 11:42 |
Defert Philippe Messages: 62 Registered: July 2009 |
Member |
Thanks , that fix my problem
Philippe
Le 22/10/2009 20:31, Andrew Niefer a écrit :
> The NullPointerException is this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=292327
> The workaround would be to remove the icons for the other platforms, or
> add some for linux.
> The JRE comes from the Launching Tab of the product editor, don't select
> the Execution Environment. (I don't like this feature since there are
> many cases where it doesn't work well).
> -Andrew
> Defert Philippe wrote:
>> Hi,
>> i want to export my product on many arch
>> i used delta pack with target configuration
>> i have 2 problems:
>> 1) in OS=win32, ARCH=x86_64, WS=win32, my product gives me an export
>> with embedded JRE, but it is 32-bit JRE for 64-bit executable that I
>> made a crash performance at execution
>> Q: where can I indicate that I do not want to export the JRE in .product?
>> 2) i can not generate a linux version 32 or 64 bits, i have this error
>> during generation
>> xxxxxxxxx\.metadata\.plugins\org.eclipse.pde.core\temp\org.e clipse.pde.container.feature\assemble.org.eclipse.pde.contai ner.feature.linux.gtk.x86_64.xml:97:
>> java.lang.NullPointerException
>> at
>> org.eclipse.pde.internal.build.tasks.BrandTask.execute(Brand Task.java:48)
>> at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
>> at sun.reflect.GeneratedMethodAccessor1275.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at
>> org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
>> at org.apache.tools.ant.Task.perform(Task.java:348)
>> at org.apache.tools.ant.Target.execute(Target.java:357)
>> at org.apache.tools.ant.Target.performTasks(Target.java:385)
>> at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
>> at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
>> at
>> org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
>> at
>> org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
>> at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
>> at
>> org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:622)
>> at
>> org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:455)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
>> at
>> org.eclipse.pde.internal.core.exports.FeatureExportOperation .runScript(FeatureExportOperation.java:422)
>> at
>> org.eclipse.pde.internal.core.exports.FeatureExportOperation .doExport(FeatureExportOperation.java:279)
>> at
>> org.eclipse.pde.internal.core.exports.ProductExportOperation .run(ProductExportOperation.java:105)
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>> Caused by: java.lang.NullPointerException
>> at java.io.FileInputStream.<init>(Unknown Source)
>> at org.eclipse.pde.internal.build.Utils.copy(Utils.java:408)
>> at
>> org.eclipse.pde.internal.build.BrandingIron.brandLinux(Brand ingIron.java:106)
>> at
>> org.eclipse.pde.internal.build.BrandingIron.brand(BrandingIr on.java:74)
>> at
>> org.eclipse.pde.internal.build.tasks.BrandTask.execute(Brand Task.java:46)
>> ... 24 more
>> --- Nested Exception ---
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
FUDForum. Page generated in 0.03312 seconds
