Home » Archived » M2M (model-to-model transformation) » [ATL] ...emfvm.VMException caused by ClassCastException, but why?
[ATL] ...emfvm.VMException caused by ClassCastException, but why? [message #491686] |
Thu, 15 October 2009 13:19  |
Hi all,
I have this rule:
--8<---------------cut here---------------start------------->8---
rule Member2Male {
from
s : Families!Member (not s.isFemale)
to
a : Persons!Address (
street <- s.family.street,
town <- s.family.town
t : Persons!Male (
address <- a,
fullName <- s.firstName + ' ' + s.family.lastName,
genealogy <- s.tree,
parents <- s.parents,
wife <- s.spouse,
ageGroup <- s.ageGroup
--8<---------------cut here---------------end--------------->8---
to create a Male for each source model Person that is not female.
Additionally, I want to create an Address. In the metamodel, there's a
composition in between: Person 0..1 <>----- 0..1 Address
The role names are person and address. Ok, when I try to run the
transformation, I get this exception.
org.eclipse.m2m.atl.engine.emfvm.VMException
at __applyMember2Male(Families2Persons.atl[81:4-81:20])
local variables: self=thisModule, link=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@4f444bef, s=IN!<unnamed>:Families!Member, a=OUT!<unnamed>:Persons!Address, t=OUT!<unnamed>:Persons!Male
at __exec__(Families2Persons.atl)
local variables: self=thisModule, e=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@4f444bef
at main(Families2Persons.atl)
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.set (EMFModelAdapter.java:637)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:451)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:387)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:197)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:162)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:135)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(Laun cherService.java:135)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDel egate.launch(AtlLaunchConfigurationDelegate.java:222)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: java.lang.ClassCastException
The source position it links to is the line "wife <- s.spouse,", but I'm
pretty sure that line is ok. If I comment out the
a : Persons!Address (...),
part and the "address <- a" line, then the transformation works as
expected, of course without creation of addresses.
I tried to create t before a, or assigning "person <- t" instead of the
other way round, but the error persists.
Any pointers?
Bye,
Tassilo
Re: [ATL] ...emfvm.VMException caused by ClassCastException, but why? [message #491722 is a reply to message #491686] |
Thu, 15 October 2009 15:01   |
--------------000903060605010505020706
There may be a problem when setting one of the street, town or address
references. Anyway, the error message isn't explicit.
Is it possible for you to send a zip containing the project (ecore
files, input model and transformation) ?
It will helps to find the error / improve the error message.
Thanks in advance,
William
Tassilo Horn a
Re: [ATL] ...emfvm.VMException caused by ClassCastException, but why? [message #491780 is a reply to message #491722] |
Thu, 15 October 2009 19:04   |
William Piers <william.piers@obeo.fr> writes:
Hi William,
> references. Anyway, the error message isn't explicit. Is it possible
> for you to send a zip containing the project (ecore files, input model
Sure, get the workspace at
http://www.uni-koblenz.de/~horn/atl-workspace.tar.gz
Bye,
Tassilo
>> rule Member2Male {
>> from
>> to
>> t : Persons!Male (
>> address <- a,
>> wife <- s.spouse,
>> Java Stack:
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>> Any pointers?
>> Bye,
>> Tassilo
Re: [ATL] ...emfvm.VMException caused by ClassCastException, but why? [message #491873 is a reply to message #491780] |
Fri, 16 October 2009 10:01   |
--------------020002050205010401000502
The error happens when you try to put an Address into the "husband" or
"wife" feature.
To rely input model elements with newly created elements, ATL uses an
implicit traceability mechanism:
if IN!A is transformed to OUT!B1, OUT!B2 (as B1 and B2 are ordered
inside of the rule, "to" section), when you refer to A it will in fact
refer to OUT!B1.
If you want to refer to B2 you need to use resolveTemp. You can read
more about resolveTemp here:
http://wiki.eclipse.org/ATL/User_Guide#The_ATL_Module_data_t ype
In your case, as you never want to refer the Address of a person, you
just have to reorder the transformation like that:
rule Member2Male {
from
to
t : Persons!Male (... -- "main" ModelElement first
rule Member2Female {
from
s : Families!Member (s.isFemale)
to
t : Persons!Female (... -- "main" ModelElement first
Best Regards,
William
Tassilo Horn a
Re: [ATL] ...emfvm.VMException caused by ClassCastException, but why? [message #491886 is a reply to message #491873] |
Fri, 16 October 2009 11:57  |
Hi William,
> "wife" feature.
> To rely input model elements with newly created elements, ATL uses an implicit
> if IN!A is transformed to OUT!B1, OUT!B2 (as B1 and B2 are ordered inside of
> the rule, "to" section), when you refer to A it will in fact refer to OUT!B1.
> If you want to refer to B2 you need to use resolveTemp. You can read more about
> resolveTemp here:
Good to know.
Yes, that does the trick.
In the meantime, I've also discovered rule inheritance, so that I don't
need to repeat myself in the Male and Females rule. Very nice.
Bye,
Tassilo
Current Time: Thu Feb 13 04:21:40 GMT 2025
Powered by FUDForum. Page generated in 0.05330 seconds
