Home » Eclipse Projects » EGit / JGit » Jgit/Egit vs Git missing functionalities?
Jgit/Egit vs Git missing functionalities? [message #491462] Wed, 14 October 2009 17:20 Go to next message
No real name is currently offline No real nameFriend
Hello!
I am a jgit/egit newbie and this is my first post so please be gentle. Embarrassed
I want to integrate a git repository in my development. I'll try to explain better: I don't want to use git as a repository for my development, I want that my application stores (add & commit) files using git and be able to recover old revisions. In addition to that I also need clone/push/pull functionality.
In order to know if git is appropiate for my needs I have been using Git from the command line to do some preliminary test. It worked OK and gave me all the functionality I needed.
When I started using jgit (and some egit functionality) in my development I noticed that, at least from egit, I couldn't perform some actions I needed. So I have 4 main questions:
1) Is it possible to perform PULL action (git fetch + git merge)?
2) How can I control, if possible, which merge strategy to use with each commiting file?
3) Is it possible to go back to a history revision without overwriting all the tree that is between the head and the wanted revision?
4) Are there any plans to implement all the functionality of git in jgit/egit? Where can I look for it?
Thank you very much in advance!
P.S: Maybe this is not the right place to post this questions. In that case, sorry!
Re: Jgit/Egit vs Git missing functionalities? [message #491548 is a reply to message #491462] Wed, 14 October 2009 23:24 Go to previous messageGo to next message
Shawn O. Pearce is currently offline Shawn O. PearceFriend
Member
JGit is more complete than EGit's UI exposes, but JGit is also missing
some features that exist within the command line C git implementation.
Fetch, yes, open a Transport object and use its fetch method.
Merge, eh, sort of. There is a start of a merge API available through
the MergeStrategy and Merger interfaces. There is a simple strategy
called SIMPLE_TWO_WAY_IN_CORE which can perform a merge in memory by
resolving paths where only one side has made an edit.
So SIMPLE_TWO_WAY_IN_CORE can handle the case where branch A modifies
file A.txt and branch B modifies B.txt just fine. It fails on merges
where both branches modify the same file, *even if* that merge would be
resolved automatically by the C git implementation.
A problem with this current API is it doesn't report where there are
conflicts, which makes it harder for the application to then define its
own merge strategy...
> commiting file?
You can't, yet. You'd essentially have to do the merge operation
completely yourself. You can read the source code of
StrategySimpleTwoWayInCore to see how one might go about doing this, but
it needs to be easier, its unreasonable to ask applications to implement
this logic themselves.
Sure, just use RevWalk to help you find that older revision, and once
you know the commit get its RevTree via RevCommit.getTree() and then go
ask a TreeWalk for the relevant file paths. Take those ObjectIds and
ask for their objects from the Repository... and there is your old content.
Re: Jgit/Egit vs Git missing functionalities? [message #491593 is a reply to message #491462] Thu, 15 October 2009 08:00 Go to previous messageGo to next message
Thank you very much for your answer!
I think they are really useful for me!
Re: Jgit/Egit vs Git missing functionalities? [message #498425 is a reply to message #491462] Mon, 16 November 2009 20:29 Go to previous messageGo to next message
Tomasz Prus is currently offline Tomasz PrusFriend
1) Is this a proper way to load repository content for path and for particular revision?
AnyObjectId objectId = repository.resolve(revision);
RevWalk walk = new RevWalk(repository);
walk.markStart(walk.parseCommit(objectId));
RevCommit revCommit = walk.lookupCommit(objectId);
TreeWalk treeWalk = TreeWalk.forPath(repository, path, revCommit.asCommit(walk).getTreeId());
treeWalk.setRecursive(true);
treeWalk.setFilter(TreeFilter.ALL);
ObjectId fileObjectId = treeWalk.getObjectId(0);
ObjectLoader objectLoader = repository.getObjectDatabase().openObject(new WindowCursor(), fileObjectId);
System.out.println("tu: " + new String(objectLoader.getBytes()));
2) How can i check if it's file or directory and then return directory structure?
3) How can i check if loaded file is text or binary?
Tomasz Prus
Re: Jgit/Egit vs Git missing functionalities? [message #498968 is a reply to message #498425] Thu, 19 November 2009 11:20 Go to previous message
Originally posted by: j16sdiz.gmail.com
Tomasz Prus wrote:
Git does not have "text"/"binary" file distinction.
All files are binary.
> Best regards,
> Tomasz Prus
Re: Jgit/Egit vs Git missing functionalities? [message #575702 is a reply to message #498425] Thu, 19 November 2009 11:20 Go to previous message
Tomasz Prus wrote:
> Best regards,
> Tomasz Prus
Previous Topic:Jgit/Egit vs Git missing functionalities?
Next Topic:redundand file revisions when iterating over branches
Current Time: Tue Apr 16 09:40:21 GMT 2024
Powered by FUDForum. Page generated in 0.16406 seconds
