Re: Attach the Java Debugger [message #491616 is a reply to message #491413] |
Thu, 15 October 2009 09:28 |
Alexander Mack Messages: 100 Registered: July 2009 |
Hello Ravi, first of all great thanks for your answer!!
Okay I tried the code you posted:
try {
ILaunchConfigurationWorkingCopy lWC = configuration.getWorkingCopy();
String projectName = configuration.getAttribute(IJavaLaunchConfigurationConstants .ATTR_PROJECT_NAME,(String) null);
//Hole den Pfad zum Projekt
File lWorkingDir = verifyWorkingDirectory(configuration);
String workingDirName = null;
if (lWorkingDir != null) {
workingDirName = lWorkingDir.getAbsolutePath();
//Lege Pfad zu den generierten java und class Dateien fest
String lGenJavaPath = lWorkingDir + System.getProperty("file.separator") + A4LPlugin.GENERATED_JAVA_FOLDER + System.getProperty("file.separator");
String lGenClassPath = lWorkingDir + System.getProperty("file.separator") + A4LPlugin.GENERATED_CLASS_FOLDER + System.getProperty("file.separator");
//Lege Main Class Datei inklusive Pfad fest:
String lMainClass = lGenClassPath + "Hello";
//Liste von classpaths fuer die VM
List lClassPathList = new ArrayList<String>();
lClassPathList.add(lGenClassPath);
ILaunchManager manager = DebugPlugin.getDefault().getLaunchManager();
if (manager != null) {
ILaunchConfigurationType type = manager.getLaunchConfigurationType(IJavaLaunchConfigurationC onstants.ID_JAVA_APPLICATION);
if (type != null) {
ILaunchConfigurationWorkingCopy workingCopy = type.newInstance( null, "a4llaunch");
workingCopy.setAttribute(IJavaLaunchConfigurationConstants.A TTR_CLASSPATH, lClassPathList);
workingCopy.setAttribute(IJavaLaunchConfigurationConstants.A TTR_MAIN_TYPE_NAME, lMainClass);
workingCopy.doSave();
List lTest = new ArrayList();
workingCopy.getAttribute(IJavaLaunchConfigurationConstants.A TTR_CLASSPATH, lTest);
ILaunch launch2 = workingCopy.launch(mode, monitor);
if (launch2 != null) {
IProcess[] processes = launch2.getProcesses();
// Use the processes if needed
} catch(Exception lEx) {
lEx.printStackTrace();
But the problem is that I always get the following exception:
java.lang.NoClassDefFoundError: D:\...\Debugging\runtime-EclipseApplication(1)\A4LLauncherTe st\bin\Hello
Caused by: java.lang.ClassNotFoundException: D:\...\Debugging\runtime-EclipseApplication(1)\A4LLauncherTe st\bin\Hello
at java.net.URLClassLoader$1.run(Unknown Source)
And eclipse says "Could not find main class:
I think it is a classpath problem isn't it?
Thanks for your help
Best Regards,
Alex
[Updated on: Thu, 15 October 2009 09:56] Report message to a moderator
Re: Attach the Java Debugger [message #492361 is a reply to message #491413] |
Tue, 20 October 2009 08:32 |
I have still one problem left but first some information:
We are generating java code out of our own 4GL.
To debug our code we want to use JSR045, Darin Wright told me that eclipse supports it.
Now we have our own language editor with CodeAssist, SyntaxHighlighting, we can toggleBreakpoints e.c. .
To debug our code we create a SMAP file and add it to the generated .class file (SourceDebugExtension)
Via console (jdb) we can now debug our 4GL code.
Via eclipse it doesn't work
Launching the application still works fine, but debugging doesn't work att all. It seems that the breakpoints we toggled are still ignored...
Here a little code how we attach the java-launcher. Perhaps I forgot something or the way I'am doing is quiet wrong:
//cretae configuration
ILaunchConfiguration lLaunchConfig = createConfiguration(lSelectedFile);
//Launch config
try {
lLaunchConfig.launch(mode, null);
} catch (CoreException e) {
e.printStackTrace();
private ILaunchConfiguration createConfiguration(IFile pFile) {
ILaunchConfiguration config = null;
ILaunchConfigurationWorkingCopy wc = null;
//Get classpath and class file name for our 4Gl file
String lClassPath = Utils.getJavaOutputFolderForProject(pFile.getProject());
String lClassName = pFile.getName().replace(".a4l", "");
try {
//Make the classpath list of mementos
List<String> lClassPathList = new ArrayList<String>();
lClassPathList.add(Utils.createClassPathEntryForPath(lClassP ath).getMemento());
//create working copy to edit
ILaunchConfigurationType configType = getAJConfigurationType();
wc = configType.newInstance(null, pFile.getName());
//set launch attributes
wc.setAttribute(IJavaLaunchConfigurationConstants.ATTR_MAIN_ TYPE_NAME, lClassName);
wc.setAttribute(IJavaLaunchConfigurationConstants.ATTR_CLASS PATH, lClassPathList);
wc.setAttribute(IJavaLaunchConfigurationConstants.ATTR_DEFAU LT_CLASSPATH, false);
config = wc.doSave();
} catch (CoreException exception) {
exception.printStackTrace();
return config;
Perhaps I have to implement some SourceLookup interfaces?
I would appreciate any help, because information at this topic is stll rare.
Thanks and best regards
Alex
[Updated on: Tue, 20 October 2009 08:32] Report message to a moderator
Re: Attach the Java Debugger [message #492622 is a reply to message #491413] |
Wed, 21 October 2009 07:00 |
Hello Ravi, first thanks for your answer again
Okay, the problem were registering the line breakpoint.
If I create the following breakpoint:
IJavaStratumLineBreakpoint lStratumBreakpoint = JDIDebugModel.createStratumBreakpoint(resource, "a4l" , lBreakpointName, null, null, lLineNumber+1, lStartChar, lEndChar, lHitCount, true, null);
The debugger ignores it (Doesn't matter if I replace the two null values to the sourcePath and Class name for example "Hello")
But if I set the LaunchConfig attribute ATTR_DEFAULT_SOURCE_PATH to false the breakpoint is NOT ignored
If I create JavaBreakpoint instead the DefaultSourcePath attribute doesn't matter, the breakpoint is never ignored
JDIDebugModel.createLineBreakpoint(resource,"Hello",lLineNumber+1,-1,-1,0,true,null);
But the problem is that in both cases the source file cannot be found.
I think I have to add the Path of our 4GL file which is translated into Java to the LaunchConfiguration by the Property ATTR_SOURCE_PATH like you said...
But how do I create a Source-Path-Memento of a String?
For a ClassPathEntry I can user JavaRuntime.newStringVariableClasspathEntry(lGenClassPath) but I don't know how to get a SourcePathMemento...?
EDIT:
I think I know what the problem is:
In the clas DirectorySorceContainer the method:
public Object[] findSourceElements(String name) throws CoreException {
ArrayList sources = new ArrayList();
File directory = getDirectory();
File file = new File(directory, name);
if (file.exists() && file.isFile()) {
sources.add(new LocalFileStorage(file));
//check sub-folders
if ((isFindDuplicates() && fSubfolders) || (sources.isEmpty() && fSubfolders)) {
ISourceContainer[] containers = getSourceContainers();
for (int i=0; i < containers.length; i++) {
Object[] objects = containers[i].findSourceElements(name);
if (objects == null || objects.length == 0) {
continue;
if (isFindDuplicates()) {
for(int j=0; j < objects.length; j++)
sources.add(objects[j]);
} else {
sources.add(objects[0]);
break;
if(sources.isEmpty())
return EMPTY;
return sources.toArray();
has the wrong parameters.
name is:
D:\...\Debugging\runtime-EclipseApplication(1)\Test\src\Hell o.a4l
and directory is
So File file = new File(directory, name); returns a file referencing whether a directory nor a file.
Atm I don't know how to solve it...
Big thanks for help!
Best regards, Alex
[Updated on: Wed, 21 October 2009 12:26] Report message to a moderator
Re: Attach the Java Debugger [message #493845 is a reply to message #491413] |
Wed, 28 October 2009 09:37 |
Ah okay thanks, I did it a little different...
I just added the process of the JavaLaunch to OurLanguageLaunch Objekt.
So if the javaLaunch process terminates, our LaunchProcess terminates, too.
The next step is to add BuildPath options. Is it possible to get the java Build Path dialog and use it for our purposes?
Because the language is translated into java, we exactly need the same dialog with its options.
Further it's curious that myLaunchConfiguration and the javaLaunchConfiguratio which is created by the first differ a little bit. Although I save the changes on the working copies of both, it seems that something doesn't work. E.g. I add a new source path (lRelativeProjectSourcePath):
//create runtime classpath entry
IRuntimeClasspathEntry lSourceLookup = JavaRuntime.newStringVariableClasspathEntry(lRelativeProject SourcePath);
//create list of source path mementos for the JVM
launch.getSourceLocator();
List<String> lSourceList = null;
//Now Add the user entries
if(lA4LConfigWorkingCopy.hasAttribute(IJavaLaunchConfigurati onConstants.ATTR_SOURCE_PATH)) {
lSourceList = lA4LConfigWorkingCopy.getAttribute(IJavaLaunchConfigurationC onstants.ATTR_SOURCE_PATH, (List) null);
} else {
lSourceList = new ArrayList<String>();
//Add our standard A4L Source Path
lSourceList.add(lSourceLookup.getMemento());
//add the java standard sources
for(IRuntimeClasspathEntry lCurrentDefaultEntry : lDefaultEntries) {
if(!lSourceList.contains(lCurrentDefaultEntry.getMemento())) {
lSourceList.add(lCurrentDefaultEntry.getMemento());
//set attributes to JavaLaunchConfiguration
lJavaConfigWorkingCopy.setAttribute(IJavaLaunchConfiguration Constants.ATTR_SOURCE_PATH, lSourceList);
lJavaConfigWorkingCopy.setAttribute(IJavaLaunchConfiguration Constants.ATTR_DEFAULT_SOURCE_PATH, false);
lJavaConfigWorkingCopy.setAttribute(IJavaLaunchConfiguration Constants.ATTR_DEFAULT_CLASSPATH, false);
//set attributes to A4LLaunchConfiguration wrokingCopy
lA4LConfigWorkingCopy.setAttribute(IJavaLaunchConfigurationC onstants.ATTR_SOURCE_PATH, lSourceList);
lA4LConfigWorkingCopy.setAttribute(IJavaLaunchConfigurationC onstants.ATTR_DEFAULT_SOURCE_PATH, false);
lA4LConfigWorkingCopy.setAttribute(IJavaLaunchConfigurationC onstants.ATTR_DEFAULT_CLASSPATH, false);
Now looking at the created JavaLaunchConfiguration SourceLookupTab, the Default folder contains my added lRelativeProjectSourcePath.
But looking at myLaunchConfiguration SourceLookupTab (which is the java one), the Default folder does NOT contain my added lRelativeProjectSourcePath.
Another problem is, that I cannot add a source attachment path to a classpath Entry:
//create runtime classpath entry for standard lib files an sources
String lStandardLibRootFolder = A4LWizard.getDefault().getPreferenceStore().getString(A4LWiz ard.KEY_FOR_STANDARDLIBRARY_LOCATION_PREFERENCE);
String lStandardLibSources = lStandardLibRootFolder + System.getProperty("file.separator") + "src";
String lStandardLibClasses = lStandardLibRootFolder + System.getProperty("file.separator") + "bin";
IRuntimeClasspathEntry lStandardLib = JavaRuntime.newStringVariableClasspathEntry(lStandardLibClas ses);
lStandardLib.setClasspathProperty(IRuntimeClasspathEntry.USE R_CLASSES);
lStandardLib.setSourceAttachmentRootPath(Path.EMPTY);
lStandardLib.setSourceAttachmentPath(new Path(lStandardLibSources));
Looking at
IRuntimeClasspathEntry[] lEntries = JavaRuntime.computeUnresolvedRuntimeClasspath(lA4LConfigWork ingCopy);
shows me that the sourceAttachmentPath and RootPath is null althoug I added it...?!
Best regards and great thank for your help again ravi.
Alex
[Updated on: Wed, 28 October 2009 14:47] Report message to a moderator
FUDForum. Page generated in 0.03897 seconds
