Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Lazy-loading one-to-many EList
[Teneo] Lazy-loading one-to-many EList [message #490910] Mon, 12 October 2009 11:33 Go to next message
Frank Grimm is currently offline Frank GrimmFriend
Dear newsgroup,
I've got a beginners question regarding Teneo (in combination wiht
Hibernate and H2 DB): I'm struggling with lazy-loading an EList. The
model looks like this:
[ EClass ] [ EClass ]
[ M ] <>---(0..*)-> [ N ]
[(extends Base)] [(extends Base)]
I.e. an instance of M owns many instances N.
Base is an abstract class with a property 'name' of type 'EString.'
Even though I set PersistenceOptions.SET_PROXY to true, I'm not able to
turn M's getter for Ns (EList<N> getNs()) into a lazy-loaded EList.
The Hibernate mapping generated by Teneo looks like this:
<subclass name="teneotests.test1_1toM.impl.MImpl"
entity-name="M" abstract="false" lazy="true" extends="Base"
discriminator-value="M" proxy="teneotests.test1_1toM.M">
<meta attribute="eclassName">M</meta>
<meta attribute="epackage">http://test1_1toM</meta>
<list name="ns" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="m_ns">
<column name="`m_ns_name`"
not-null="false" unique="false"/>
</key>
<list-index column="`m_ns_idx`"/>
<one-to-many entity-name="N"/>
</list>
</subclass>
<subclass name="teneotests.test1_1toM.impl.NImpl" entity-name="N"
discriminator-value="N" proxy="teneotests.test1_1toM.N">
<meta attribute="eclassName">N</meta>
</subclass>
I'm not sure whether the problem has to do with M's one-to-many mapping
not having its lazy attribute set to true.?
Lazy loading works for one-to-one references; then a
JavassistLazyInitializer is created instead of a proper EList
implementation.
Many thanks in advance,
Frank
Re: [Teneo] Lazy-loading one-to-many EList [message #490916 is a reply to message #490910] Mon, 12 October 2009 11:53 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Frank,
Afaics the list is mapped with lazy=true, so it should be lazily-loaded. Or do you see something different?
Is it maybe that you expect the content of the lazy-loaded list to also be proxied objects. Afaik Hibernate does not use
proxies for content of a collection.
Also if you check the collection in a debugger then this may load the list. So the best is to enable hibernate sql
logging to see at which point hibernate fires certain queries.
Btw, support for Teneo is given on the main EMF newsgroupo which I added to the cc.
gr. Martin
Frank Grimm wrote:
> Dear newsgroup,
> </key>
> </list>
> </subclass>
> </subclass>
> implementation.
> Frank
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Lazy-loading one-to-many EList [message #491070 is a reply to message #490916] Tue, 13 October 2009 07:07 Go to previous message
Dear Martin,
thank you for your prompt reply!
Indeed, the list is lazily loaded.
> be proxied objects. Afaik Hibernate does not use proxies for content of
> a collection.
Arrg, I mistook proxying for lazy loading.
> list.
Yep, that was what made me think the list wasn't lazily loaded.
> to the cc.
Alright, thanks, will post there next time I've got a Teneo related
question.
Frank
> Frank Grimm wrote:
>> Dear newsgroup,
>> </key>
>> </list>
>> </subclass>
>> </subclass>
>> implementation.
>> Frank
Re: [Teneo] Lazy-loading one-to-many EList [message #621455 is a reply to message #490910] Mon, 12 October 2009 11:53 Go to previous message
Hi Frank,
gr. Martin
Frank Grimm wrote:
> Dear newsgroup,
> </key>
> </list>
> </subclass>
> </subclass>
> implementation.
> Frank
The Netherlands
Re: [Teneo] Lazy-loading one-to-many EList [message #621457 is a reply to message #490916] Tue, 13 October 2009 07:07 Go to previous message
Dear Martin,
> a collection.
> list.
> to the cc.
question.
Frank
> Frank Grimm wrote:
>> Dear newsgroup,
>> </key>
>> </list>
>> </subclass>
>> </subclass>
>> implementation.
>> Frank
Previous Topic:How to get involve
Next Topic:Property "Unique" for ecore attribute doesn't work
Current Time: Tue Aug 09 22:40:36 GMT 2022
Powered by FUDForum. Page generated in 0.04600 seconds
