Home » Modeling » M2T (model-to-text transformation) » [JET] OCL/Profiles(JET and OCL - JET and profiles)
[JET] OCL/Profiles [message #490895] Mon, 12 October 2009 09:55 Go to next message
Siegfried Nolte is currently offline Siegfried NolteFriend
Member
(1) Is it possible to combine JET with OCL, means to do some OCL actions in a JET-template?
(2) Is it possible to retrieve UML profile information in a JET-template?
Thanks for answer,
Siegfried
Re: [JET] OCL/Profiles [message #491146 is a reply to message #490895] Tue, 13 October 2009 13:18 Go to previous message
Paul Elder is currently offline Paul ElderFriend
Siegfried:
Out-of-the-box, JET includes not support for OCL. But, there is nothing preventing you from creating a custom tag or two (equivalent to c:get, c:iterate and c:if, for example) that use OCL instead of XPath. It has been done - unfortunately, the individual who did it was unable to contribute it back to the project Sad
As for accessing UML profiles with the XPath engine, this is possible. The Galileo release (M2T JET 1.0.0) includes uml2.stereotype function:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .jet.doc/references/xpathFunctions/uml2.stereotypeFunction.h tml
It lets you test for and access a UML2 stereotype for any UML element. The function is roughly equivalent to calling this UML2 API:
http://help.eclipse.org/galileo/topic/org.eclipse.uml2.doc/r eferences/javadoc/org/eclipse/uml2/uml/Element.html#getStere otypeApplication(org.eclipse.uml2.uml.Stereotype)
Since the API returns an EObject, you can use XPath expressions to access its attributes. E.g.
uml2.stereotype(/Model,'Foo::Bar')/@someProperty
or
//Package[uml2.stereotype('Ultimate::Question')/@answer = 42]
Paul
Previous Topic:Patch for <jet.compile> (<jet.compile2) gives null pointer exceptions
Next Topic:Re: Code generation in a Standalone Java Application
Current Time: Wed Dec 07 00:26:57 GMT 2022
Powered by FUDForum. Page generated in 0.02288 seconds
