Home » Eclipse Projects » Mylyn » Automatic changesets aren't, well, doing anything
Automatic changesets aren't, well, doing anything [message #490388] |
Thu, 08 October 2009 14:14 |
Bill Messages: 12 Registered: October 2009 |
I suspect user error, but I don't know what I'm doing wrong. I have automatic changeset management turned on in my preferences. If I activate a task from a project that's linked with an SVN repository, open a file, make a change, and save it, I see the change in the Synchronize view, but it's not associated with any changeset (none are created). I can right-click on it and manually assign it to a new changeset, but by itself it's not creating one.
Since it's all automagic, I'm not sure how to troubleshoot this. Any tips?
Eclipse Galileo 20090621-0832
Mylyn 3.2.2
Subclipse 1.6.5
Mylyn Team Support is installed
Re: Automatic changesets aren't, well, doing anything [message #490404 is a reply to message #490388] |
Thu, 08 October 2009 14:36 |
Mark Phippard Messages: 129 Registered: July 2009 |
> Mylyn 3.2.2
> Subclipse 1.6.5
Are you closing the editor? That removes the file from the changeset.
Mark
Re: Automatic changesets aren't, well, doing anything [message #490446 is a reply to message #490431] |
Thu, 08 October 2009 16:37 |
Mauro Molinari wrote on Thu, 08 October 2009 11:49 |
Maybe your problem is Subclipse? Maybe you have to install some kind of
Mylyn-integration for it?
Mauro.
Those were the magic words. I wasn't aware of it until you said this and I went searching, but it turns out the Tigris Subclipse 1.6 update site (http://subclipse.tigris.org/update_1.6.x) offers a package called "Subclipse Integration for Mylyn 3.x." I installed version 3.0.0 of this package and now it's working.
For some reason I had to go into my prefs and turn off automatic changeset management, apply settings, and then turn it back on. As soon as I did that it started working.
Thank you so much!
[Updated on: Thu, 08 October 2009 16:37] Report message to a moderator
Re: Automatic changesets aren't, well, doing anything [message #490479 is a reply to message #490466] |
Thu, 08 October 2009 19:02 |
On 2009-10-08 14:04:17 -0400, Bill <bkocik@gmail.com> said:
> Mark Phippard wrote on Thu, 08 October 2009 13:26
>> I am sorry for not suggesting that. In your original email I read this:
>> "Mylyn Team Support is installed"
>> and for some reason I read it as that you had installed the
>> Subclipse/Mylyn integration.
> No need for apologies - I appreciate everyone's help. :)
>> This integration should also cause references to tasks within your log
>> messages in the History view to open in Mylyn.
> That actually doesn't work, but I suspect that's a failing of my
> repository connector. I use Redmine, and the plugins for that are
> pretty young and not yet very robust.
> However it is writing my commit comments for me automatically, which is nice.
In your project properties, Mylyn contributes a page that lets you
associate the project with a Task Repository. Try that. Also, I think
it only works if you do Show History from your working copy (as opposed
to from the SVN Repositories view).
Mark
Re: Automatic changesets aren't, well, doing anything [message #599505 is a reply to message #490388] |
> Mylyn 3.2.2
> Subclipse 1.6.5
Mark
Re: Automatic changesets aren't, well, doing anything [message #599582 is a reply to message #599575] |
Mark
Current Time: Wed Apr 24 18:55:58 GMT 2024
Powered by FUDForum. Page generated in 0.04641 seconds
