Re: Validation with own AbstractObservableValue [message #490730 is a reply to message #490066] |
Fri, 09 October 2009 21:17 |
Originally posted by: TheRealHawk.Freenet.de
Could it be, that you've only implemented doGetValue() and doSetValue()?
You also have to observe your property or control and fire the events by
your self.
--> If you want to observe a control you should extend
AbstractSWTObservableValue
Greetings
Markus
"T. Wilhelm" <t.wilhelm@msh.de> schrieb im Newsbeitrag
news:hahfbq$sh5$1@build.eclipse.org...
> Hey all,
> i use databinding in my RCP application and i needed my own
> AbstractObservableValue. So i create a class (MyObservableValue), extend
> it from AbstractObservableValue and everything works fine first. Then i
> added a validator to my binding. My Problem now is that the validator is
> never called :( I
Re: Validation with own AbstractObservableValue [message #491027 is a reply to message #490736] |
Mon, 12 October 2009 21:19 |
Where can I find more informations about the new api?
Currently I only work with SWTObservables, BeansObservables, PojoObservables
and ViewersObservables.
What are IValueProperties and how to I use them?
Markus
"Matthew Hall" <matthall@woodcraftmill.com> schrieb im Newsbeitrag
news:haoctv$69l$1@build.eclipse.org...
> AbstractSWTObservableValue is not public API and was removed in the latest
> version of DataBinding (June '09). The recommended approach is to use the
> new property API, there is a new API class WidgetValueProperty for this
> purpose.
> To extend WidgetValueProperty properly you need to do just a few things:
> * Implement the abstract getter and setter methods.
> * Implement the getValueType() method
> * If the widget property fires change events, pass the SWT event
> constant(s) to the superconstructor in your custom property's constructor
> * (Recommended) Implement toString() to provide a programmer-friendly
> description of the property.
> IWidgetValueProperty myCustomProp = new MyCustomWidgetProperty();
> ISWTObservableValue observable = myCustomProp.observe(theWidget);
> Hope this helps,
> Matthew
>> your self.
>> Greetings
>> Markus
>>> Hey all,
>>> never called :( I
FUDForum. Page generated in 0.04034 seconds
