Resources.getResource not found [message #490026] |
Wed, 07 October 2009 00:27 |
Eclipse can't find the specified resources by
"Resources.getResource" ....
What's wrong?
This seems always happens and it's absolutely annoying.
The thing is, I even added this resource directory into my project source.
What can I do??
Best Regards
JIA
[Updated on: Thu, 08 October 2009 05:43] Report message to a moderator
Re: resources not found [message #490252 is a reply to message #490057] |
Thu, 08 October 2009 05:57 |
Sorry, I'm actually building and testing
j3d-examples in Eclipse 3.5.1 IDE, under WindowsXP.
Resources is actually defined as the attached file. In fact, this Resource.java file is as simple as
package org.jdesktop.j3d.examples;
import java.net.URL;
public class Resources {
* Do not construct an instance of this class.
private Resources() {
* Return the URL of the filename under the resources directory
public static URL getResource(String filename) {
URL url = Resources.class.getResource(filename);
return url;
I tacked into the source, it seems the function
public java.net.URL getResource(String name)
in class
can't find the resource files, which makes url in
always be null.
Can you please help?
Cheers
JIA Pei
FUDForum. Page generated in 0.03390 seconds
