Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » Proposed feature: Export user defined symbols as separated .properties files
Proposed feature: Export user defined symbols as separated .properties files [message #489936] Tue, 06 October 2009 14:28 Go to next message
David Lucena is currently offline David LucenaFriend
Member
I have seen that the symbols defined in custom symbols sets get exported together with the device symbols set in a single .properties file. It would be more flexible to export them in separated .properties files, each file with the name of the symbol set, so that the later customization of the build script would be simpler.
I think this would be a great improvement, but don't know if it is hard to implement it.
David.
PD.- By the way, any progress about the latest antenna preprocessor release request to eclipse foundation?
[Updated on: Tue, 06 October 2009 15:06]
Report message to a moderator
Re: Proposed feature: Export user defined symbols as separated .properties files [message #492931 is a reply to message #489936] Thu, 22 October 2009 12:13 Go to previous messageGo to next message
Diego Madruga Sandin is currently offline Diego Madruga SandinFriend
Member
Hi David,
I thinks this is a good improvement for mtj. Since we are planning the next release, could you open a bug request on bugzilla or maybe send an email to the developer mailing list?
About the preprocessor upgrade, I'll be opening the request to the IP team this weekend. I'll keep you informed.
Diego
Re: Proposed feature: Export user defined symbols as separated .properties files [message #493416 is a reply to message #492931] Mon, 26 October 2009 06:56 Go to previous messageGo to next message
Member
Diego Madruga Sandin wrote on Thu, 22 October 2009 08:13
Hi David,
I thinks this is a good improvement for mtj. Since we are planning the next release, could you open a bug request on bugzilla ...
Done and...
thanks.
Re: Proposed feature: Export user defined symbols as separated .properties files [message #496039 is a reply to message #493416] Sat, 07 November 2009 13:32 Go to previous messageGo to next message
Member
Hi David,
I've opened the request to upgrade to the newer version of antenna.preprocessor. I'm now waiting for PMC approval to start the IP process.
Hopefully that wont take long.
Diego
Re: Proposed feature: Export user defined symbols as separated .properties files [message #502484 is a reply to message #496039] Tue, 08 December 2009 14:06 Go to previous messageGo to next message
Member
Hi David,
We received an OK to upgrade the preprocessor. I've opened a new bug to address that (Bug 297200) .
Diego
Re: Proposed feature: Export user defined symbols as separated .properties files [message #503754 is a reply to message #502484] Tue, 15 December 2009 15:56 Go to previous messageGo to next message
Member
Nice news! Thank you very much!
Re: Proposed feature: Export user defined symbols as separated .properties files [message #578518 is a reply to message #496039] Tue, 08 December 2009 14:06 Go to previous messageGo to next message
Member
Hi David,
We received an OK to upgrade the preprocessor. I've opened a new bug to address that (https://bugs.eclipse.org/bugs/show_bug.cgi?id=297200) .
Diego
Re: Proposed feature: Export user defined symbols as separated .properties files [message #578643 is a reply to message #578518] Tue, 15 December 2009 15:56 Go to previous message
Member
Previous Topic:Re: Flag disallowed Java SE keywords as errors
Next Topic:Eclipse Galileu + MTJ + Perst Lite
Current Time: Mon Apr 19 21:38:59 GMT 2021
Powered by FUDForum. Page generated in 0.02341 seconds
