Re: Get imagefilename with swtbot [message #489068 is a reply to message #489035] |
Thu, 01 October 2009 12:29 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
Images in SWT are just data structures that store image information --
colors, pixels, etc, but not the file information.
You may read an existing file and perform an equals with the image on
the widget to see if the image is what you expect.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 01/10/09 3:20 PM, Michelle Davidson wrote:
> Hello,
> is there a way to check with swtbot, if the image, which is shown on a
> lable, or a treeitem or on another widget, ist the correct image.
> I look for a methode that returns the name of this image file, so that i
> can compare this filename with the correct file name.
Re: Get imagefilename with swtbot [message #489297 is a reply to message #489068] |
Fri, 02 October 2009 09:42 |
Originally posted by: cedric.chabanois.entropysoft.net
Here is what I use to compare two ImageData (you can get ImageData from
ImageDescriptor or from Image)
public static void assertImageDataIs(ImageData expectedImageData,
ImageData actualImageData) {
if (expectedImageData.width != actualImageData.width
|| expectedImageData.height != actualImageData.height) {
fail(MessageFormat
.format(
"Image data do not have the same dimensions ({0}x{1} expected, got
{2}x{3})",
expectedImageData.width, expectedImageData.height,
actualImageData.width, actualImageData.height));
for (int y = 0; y < expectedImageData.height; y++) {
for (int x = 0; x < expectedImageData.width; x++) {
int actualPixel = actualImageData.getPixel(x, y);
int expectedPixel = expectedImageData.getPixel(x, y);
RGB actualRGB = actualImageData.palette.getRGB(actualPixel);
RGB expectedRGB = expectedImageData.palette
.getRGB(expectedPixel);
if (!actualRGB.equals(expectedRGB)) {
fail(MessageFormat.format(
"Image data do not match at ({0},{1})", x, y));
C
FUDForum. Page generated in 0.03171 seconds
