Re: [TENEO] 3 Tier architecture. Is it possible [message #488721 is a reply to message #488696] |
Tue, 29 September 2009 21:48 |
Hi Waldi,
I can't really comment on the RCP-application server integration. I know that other people (Flavio Donze) have used
Rienna but I think that you have seen these posts. Regarding authorization/authentication that part is something you
need to develop yourselve... This together with other server side code. The nice thing of using EMF/Teneo in
Jboss/Tomcat is that you can easily write server-side code.
Btw, as Tom mentions the combination of CDO/Teneo is a really good solution to. I spend a lot of time in July to improve
the quality, these changes are all available in the CDO 3.0 stream (HEAD in cvs). I will probably spend some more time
on it a little later this month.
gr. Martin
Tom Schindl wrote:
> You should take a look at my EclipseCon presentation [1] where I use
> CDO+Teneo because then you get a real 3-tier application.
> The problem you are going to face if you are using other technologies is
> the problem of lazy loading which is only automatically solved by CDO.
> Tom
> [1]http://live.eclipse.org/node/742
> Waldi Waldemar schrieb:
>> Dear EMF Group,
>> is it possible to use Teneo in a typical 3 tier architecture
>> environment? I spend a lot of time to play with the the Sample Library
>> project. Now I have a persistence Service (Teneo Persistence Service)
>> who is really awesome. In my rcp application all works automaticaly...
>> The data binding, save, delete change detection... Now it would be realy
>> awesome if I can publish this Service from a application Server like
>> JBoss or Tomcat and access it from my rcp application. But all the try
>> was without success. Can you help me in this direction?
>> BTW: I try out riena... without success. There is a post in the Riena
>> newsgroup from me about eclipse.ui dependency about my problem.
>> The ground if I ask is: Authentication and Authorization... With Teneo
>> there is no possibility to do this.
>> Thanks in advance
>> Waldi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] 3 Tier architecture. Is it possible [message #488803 is a reply to message #488789] |
Wed, 30 September 2009 09:43 |
Hi Waldi,
To clarify the different options in which Teneo can be used (maybe also interesting for others):
- rcp connects directly to teneo using the HibernateResource(Factory) etc. This is a fine architecture but you won't
have the features offered by CDO (see below).
- Teneo runs inside a web container like jboss or Tomcat. Then you can place different front-ends on top of this:
> a web browser,
> another server doing webservice calls
> a rcp
The first two are a good fit directly, especially webservice environments.For RCP you have to to do all the
rcp-webserver communication yourselve (the main disadvantage of this architecture). However, this is also doable it
seems as people have done this. The advantage of this architecture is that you have real EMF objects available on the
server so you can easily write server side code using the EMF/Teneo/Hibernate constructs.
- Teneo embedded in CDO (3.0): in this case the Teneo mapping layer operates inside of CDO. Many Teneo mapping
constructs/annotations are supported (but not all). CDO offers really nice RCP features (like lazy loading, but also
auto-memory management, broadcasting of changes between clients etc.). You can even do HQL queries in the RCP to build
your UI independent of EMF resource structures. So all in all a good architecture combining CDO's advanced features with
Teneo's mapping flexibility and Hibernate's multi-database support. One disadvantage/drawback of the CDO 3.0/Teneo
integration is that not all EMF features are yet supported, mainly the featuremap is not supported (this is a todo for
CDO/Teneo)*. Also CDO will add its own tables to the database (resource, folder, epackages etc.). And in addition
because CDO uses its own framework on the server it is more difficult to build server side logic (at least afaiu).
I am sure Eike and other CDO committers can add remarks on CDO features, but this is just a summary.
I hope this description is usefull/helpfull for you and also others.
Let me know if you have any other questions/remarks.
* note that CDO has multiple backends which have different features, like I think that the featuremap is now supported
by the default CDO DB backend.
gr. Martin
Waldi Waldemar wrote:
> Sorry I don't refresh my Inbox and haven't read you message.
> Martin Taal schrieb:
>> Hi Waldi,
>> know that other people (Flavio Donze) have used Rienna but I think
> Hmm I will search after it
>> is something you need to develop yourselve... This together with other
>> server side code. The nice thing of using EMF/Teneo in Jboss/Tomcat is
> Yes but my problem is to get run Teneo on the Server side. But you say
> Flavio Donze.... I will look after it
>> solution to. I spend a lot of time in July to improve the quality,
>> will probably spend some more time on it a little later this month.
> I'm curious about it.
>> gr. Martin
>>> Tom
>>>> Dear EMF Group,
>>>> realy
>>>> Thanks in advance
>>>> Waldi
The Netherlands
FUDForum. Page generated in 0.02853 seconds
