Application could not be found in the registry. [message #488438] |
Mon, 28 September 2009 12:32  |
A colleague of mine built a project using Eclipse 3.4 last year and I have been asked to resurrect the project and get it updated for Eclipse 3.5. I checked it out of CVS and tried to run it from the Plugin Testing section, "Launch an Eclipse Application." When I do this, I get the following error message:
!SESSION 2009-09-28 11:30:36.740 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_20
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -application edu.illinois.mobius.datamanager.application
Command-line arguments: -application edu.illinois.mobius.datamanager.application -data /Users/kjkeefe/workspace/../runtime-edu.illinois.mobius.datamanager.application -dev file:/Users/kjkeefe/workspace/.metadata/.plugins/org.eclipse.pde.core/edu.illinois.mobius.datamanager.application/dev.properties -os macosx -ws cocoa -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-09-28 11:30:37.420
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "edu.illinois.mobius.datamanager.application" could not be found in the registry. The applications available are: org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2009-09-28 11:30:37.436
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-09-28 11:30:37.436
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.core_3.2.300.v20090525.jar/ was not resolved.
!SUBENTRY 2 org.eclipse.update.core 2 0 2009-09-28 11:30:37.436
!MESSAGE Missing required bundle org.eclipse.core.net_[1.0.0,2.0.0).
!ENTRY org.eclipse.osgi 2 0 2009-09-28 11:30:37.437
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-09-28 11:30:37.437
!MESSAGE Bundle org.eclipse.update.ui_3.2.200.v20090213 [19] was not resolved.
!SUBENTRY 2 org.eclipse.update.ui 2 0 2009-09-28 11:30:37.437
!MESSAGE Missing required bundle org.eclipse.update.core_[3.1.0,4.0.0).
!MESSAGE Bundle edu.illinois.mobius.datamanager_2.3.0 [24] was not resolved.
!SUBENTRY 2 edu.illinois.mobius.datamanager 2 0 2009-09-28 11:30:37.437
!MESSAGE Missing required bundle org.eclipse.update.ui_0.0.0.
!MESSAGE Bundle org.eclipse.update.core_3.2.300.v20090525 [25] was not resolved.
!SUBENTRY 2 org.eclipse.update.core 2 0 2009-09-28 11:30:37.438
What does this mean? How do I add this application to the registry? Any help you can give for getting the application to run again would be GREATLY appreciated. Thanks!
Re: Application could not be found in the registry. [message #488439 is a reply to message #488438] |
Mon, 28 September 2009 12:39   |
I suggest to check your launch configuration as described here:
http://www.vogella.de/articles/RichClientPlatform/article.ht ml#runconfiguration
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
> /Users/kjkeefe/workspace/../runtime-edu.illinois.mobius.data manager.application
> -dev
> file:/Users/kjkeefe/workspace/.metadata/.plugins/org.eclipse .pde.core/edu.illinois.mobius.datamanager.application/dev.pr operties
> !STACK 1
> at
> org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
> at
> org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> !MESSAGE Bundle
> initial@reference :file:plugins/org.eclipse.update.core_3.2.300.v20090525.jar/
> was not resolved.
> !MESSAGE Bundle org.eclipse.update.ui_3.2.200.v20090213 was not
> resolved.
> !MESSAGE Bundle edu.illinois.mobius.datamanager_2.3.0 was not
> resolved.
> resolved.
FUDForum. Page generated in 0.03462 seconds
