osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #488277] |
Sun, 27 September 2009 06:41  |
I keep getting this error under (Topic).
Any Hints? (If this is the right place to ask?)
Greetings,
Ralf
P.S. Java 6 under Snow Leopard runs fine (in contrast).
java version "1.6.0_15"
Java(TM) SE Runtime Environment (build 1.6.0_15-b03-226)
Java HotSpot(TM) 64-Bit Server VM (build 14.1-b02-92, mixed mode)
java.lang.NoClassDefFoundError: Could not initialize class
com.ibm.icu.impl.JavaTimeZone
at com.ibm.icu.util.TimeZone.getDefault(TimeZone.java:804)
at com.ibm.icu.util.Calendar.getInstanceInternal(Calendar.java: 1630)
at com.ibm.icu.util.Calendar.getInstance(Calendar.java:1594)
at
com.ibm.icu.text.SimpleDateFormat.initialize(SimpleDateForma t.java:465)
at
com.ibm.icu.text.SimpleDateFormat.<init>(SimpleDateFormat.java:435)
at
com.ibm.icu.text.SimpleDateFormat.<init>(SimpleDateFormat.java:368)
at
org.eclipse.ui.internal.views.log.LogSession.setDate(LogSess ion.java:43)
at
org.eclipse.ui.internal.views.log.LogSession.processLogLine( LogSession.java:67)
at
org.eclipse.ui.internal.views.log.LogReader.parseLogFile(Log Reader.java:90)
at
org.eclipse.ui.internal.views.log.LogView.readLogFile(LogVie w.java:814)
at
org.eclipse.ui.internal.views.log.LogView.createPartControl( LogView.java:172)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at
org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2229)
at
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1067)
at
org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.j ava:3816)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3813)
at
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3789)
at
org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager$7 .widgetSelected(WorkbenchStatusDialogManager.java:1507)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3543)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1250)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1273)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at
org.eclipse.swt.widgets.Link.textView_clickOnLink_atIndex(Li nk.java:117)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4855 )
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native
Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:202)
at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:920)
at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2151)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4653 )
Method)
at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:1 753)
at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:182 5)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4713 )
Method)
at
org.eclipse.swt.widgets.Display.applicationSendEvent(Display .java:4285)
at
org.eclipse.swt.widgets.Display.applicationProc(Display.java :4352)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at
org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApp lication.java:101)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3097)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
"error.txt" 67L, 4894C
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #916463 is a reply to message #916420] |
Tue, 18 September 2012 23:23  |
On 09/18/2012 08:59 PM, Peter Kennedy wrote:
> vercout wrote on Tue, 04 January 2011 11:32
>> A best way is to add this line in eclipse.ini file :
>> -Dcom.ibm.icu.util.TimeZone.DefaultTimeZoneType=ICU
> Thank you so so much for posting this issue!!! The TimeZoneError was
> hidden in a very long and discombobulated stack trace, but on a whim I
> looked it up instead of the top level and found this. I can now read my
> C files again!!! :d Also running Ubuntu, 12.04 with Open JDK 6.
reinstalling tzdata-java solves the problem completely so you don't have
to add the line to eclipse.ini
FUDForum. Page generated in 0.06280 seconds
