Home » Eclipse Projects » Nebula » How can I use the swt ribbon in RCP
How can I use the swt ribbon in RCP [message #487978] Fri, 25 September 2009 07:58 Go to next message
Wok Show is currently offline Wok ShowFriend
Member
at first how can i replace the shell of the rcp wit the ribbon shell?
then i want to open a view with the ribbon button but no perspective will be switch. I use the
getWindowConfigurer().getWindow().getActivePage().showView(V iew ID);
greez Chau
Re: How can I use the swt ribbon in RCP [message #488016 is a reply to message #487978] Fri, 25 September 2009 10:19 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
replacing the SWT-Shell in RCP 3.x is nearly impossible so I guess you
are out of luck until e4 will be released which makes such things
possible [1] already in 0.9 (if you have a lot of knowlegde about the
internals) and we'll make it (hopefully total easy in 1.0 [2])
Beside that please take care about the license politics of M$, Ribbon is
royality free but you need to inform M$ about the usage!
Tom
[1] http://tomsondev.bestsolution.at/2009/07/02/e4-a-new-area-fo r-rcpria-applications/
[2]https://bugs.eclipse.org/bugs/show_bug.cgi?id=288998
> greez Chau
Re: How can I use the swt ribbon in RCP [message #488017 is a reply to message #488016] Fri, 25 September 2009 10:25 Go to previous messageGo to next message
This is also the reason Ribbon is not getting part of Nebula until M$
removes this restriction and can't provide support for it :-(
Tom
Re: How can I use the swt ribbon in RCP [message #488020 is a reply to message #487978] Fri, 25 September 2009 10:38 Go to previous message
Member
should i inform MS if i take this for private use?
Re: How can I use the swt ribbon in RCP [message #598262 is a reply to message #488016] Fri, 25 September 2009 10:25 Go to previous message
Tom
Previous Topic:Allow to resize row header width
Next Topic:How can I use the swt ribbon in RCP
Current Time: Mon Feb 24 12:29:29 GMT 2020
Powered by FUDForum. Page generated in 0.10786 seconds
