Home » Eclipse Projects » SWTBot » Application error on rcp using headless testing framework
Application error on rcp using headless testing framework [message #487959] Fri, 25 September 2009 00:47 Go to next message
I tried the following steps:
1. Created an rcp product and can successfully launch it from product
editor
2. I have all the swtbot and headless testing plugins in the target
platform.
3. I exported the product (for testing) which includes the swtbot and
headless testing (junit 4 only) plugins.
4. I unzipped the rcp product, cd to the eclipse directory and ran the
following:
java -Xms128M -Xmx368M -XX:MaxPermSize=256M -DPLUGIN_PATH= -classpath
C:\tmp\hdwb3\eclipse\plugins\org.eclipse.equinox.launcher_*. jar
org.eclipse.core.launcher.Main -application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -clean
-data workspace
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,allTestsJunitSummary.xml
-testPluginName com.ibm.hdwb.support.junit -className
com.ibm.hdwb.support.junit.AllTests -os win32 -ws win32 -arch x86
-consoleLog -debug
The result was:
Starting application: 9937
!SESSION 2009-09-24 23:43:28.406
eclipse.buildId=unknown
java.fullversion=J2RE 1.6.0 IBM J9 2.4 Windows XP x86-32
vmwi3260sr5-20090519_3
5743 (JIT enabled, AOT enabled)
J9VM - 20090519_035743_lHdSMr
JIT - r9_20090518_2017
GC - 20090417_AA
Framework arguments: -application
tbottestapplication
nitResultFormatter,allTestsJunitSummary.xml -testPluginName
..junit -className com.ibm.hdwb.support.junit.AllTests
Command-line arguments: -application
..swtbottestapplication -clean -data workspace
kdefs.optional.junit.XMLJUnitResultFormatter,allTestsJunitSu mmary.xml
-testPlugi
-os win32 -ws win32 -arch x86 -consoleLog -debug
!ENTRY org.eclipse.osgi 4 0 2009-09-24 23:43:38.406
!MESSAGE Application error
!STACK 1
junit.framework.AssertionFailedError: null
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.assertTrue(Assert.java:20)
at junit.framework.Assert.assertNotNull(Assert.java:214)
at junit.framework.Assert.assertNotNull(Assert.java:207)
at
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .getAppli
cation(UITestApplication.java:94)
at
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .run(UITe
stApplication.java:54)
at
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .start(UI
TestApplication.java:203)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandl
e.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runAppli
cation(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ec
lipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:368)
at
va:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
sorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:599)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
at org.eclipse.core.launcher.Main.main(Main.java:34)
Thanks for any help you can provide.
Re: Application error on rcp using headless testing framework [message #488688 is a reply to message #487959] Tue, 29 September 2009 14:18 Go to previous messageGo to next message
> editor
> platform.
> following:
> -data workspace
> -consoleLog -debug
Ketan, it looks like it cannot find an extension in UITestApplication.
Do the steps in the previous post look correct for exporting the RCP
project?
IExtension extension =
Platform.getExtensionRegistry().getExtension(
Platform.PI_RUNTIME,
Platform.PT_APPLICATIONS,
getApplicationToRun(args));
// If no 3.0 extension can be found, search the registry
// for the pre-3.0 default workbench application, i.e. org.eclipse
ui.workbench
// Set the deprecated flag to true
if (extension == null) {
extension = Platform.getExtensionRegistry().getExtension(
DEFAULT_APP_PRE_3_0);
fInDeprecatedMode = true;
Assert.assertNotNull(extension);
Re: Application error on rcp using headless testing framework [message #488689 is a reply to message #488688] Tue, 29 September 2009 14:48 Go to previous messageGo to next message
>> editor
>> platform.
>> the following:
>> -consoleLog -debug
> project?
> org.eclipse ui.workbench
Looks like the swtbottestapplication takes an argument
-testApplication <rcpApplication>
This makes sense as I was wondering how the test knew to run against the
rcp application.
So the following invocation
-data workspace -testApplication com.ibm.hdwb.client.ui.HDWB
-consoleLog -debug
Brings up the application ui.
I get another exception. I'll open a separate thread if I can't figure
it out.
Re: Application error on rcp using headless testing framework [message #488734 is a reply to message #487959] Tue, 29 September 2009 22:24 Go to previous message
Ant execution and command line args are mentioned on the wiki at
http://wiki.eclipse.org/SWTBot/Ant.
You may also look at the ant script for the command line arguments. I'd
recommend using the ant scripts since they do lot more validation about
various execution params.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
> editor
> platform.
> following:
> -data workspace
> -consoleLog -debug
> The result was:
> GC - 20090417_AA
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> tbottestapplication
> -testPlugi
> !STACK 1
> at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .getAppli
> at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .run(UITe
> at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .start(UI
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandl
> e.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runAppli
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ec
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
> va:368)
> va:179)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
> java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
> sorImpl.java:37)
Previous Topic:Returning to a base state after an error...?
Next Topic:Enhancement suggestions for the WithId matcher
Current Time: Thu Jul 17 22:03:54 EDT 2025
Powered by FUDForum. Page generated in 0.04428 seconds
