Re: Using SWT Bot with GMF - GEF [message #530794 is a reply to message #487807] |
Sat, 01 May 2010 02:03 |
Steven Chamberlin Messages: 30 Registered: July 2009 |
Member |
Hi Mariot, or others who may know ...
First, I'm having some trouble finding good examples of SWT-Bot code with GEF. I clicked on that link but it says the bug cannot be found.
Second, I have a situation where I am trying to test a GEF editor. and whenever the mouse is positioned in this GEF editor, without even clicking on anything, just hovering, a toolbar pops up (assuming the mouse isn't moving). However, SWT-Bot spy view doesn't change as I hover over the toolbar buttons.
It shows:
//Shell/-1//Composite/4//Composite/0//Composite/10//Composit e/0//Composite/0//FlyoutPaletteComposite/0//RulerComposite/2 //FigureCanvas/0
I tried accessing these buttons with the GEF toolBarButton API, using the tooltip string, but it does not recognize them. Any idea?
Finally, is there a way to search for objects created in the GEF editor, so that you can get their x,y positions? Say if you wanted to find a node so that you could then draw a line from that node to another node.
Thanks!
Steve
Re: Using SWT Bot with GMF - GEF [message #530948 is a reply to message #530794] |
Mon, 03 May 2010 07:14 |
You can find some examples of SWTBot tests on GMF editor in Bonita Open Solution code base [1].
AFAIK, you'll have to use the "regular" GEF API to retrieve your diagram, browse it to find your nodes, and get locations from the figures of EditParts.
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
FUDForum. Page generated in 0.03394 seconds
