Home » Eclipse Projects » Riena » Problem accessing remote service
Problem accessing remote service [message #487633] |
Wed, 23 September 2009 20:20 |
Jens Mayer Messages: 19 Registered: September 2009 Location: Hamburg |
i'm trying to create an example using riena following the Demo-Client-Example, unfortunately i don't get the client-side working.
This is what i've done yet:
1.) creating the server side, starting a service registered with the Interface IMenuSupport. After starting the service, i can see in the console-output:
Wed Sep 23 21:55:28 CEST 2009 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.internal.communication.publisher.hessian.H essianRemoteServicePublisher published web service. protocol=hessian, url=http://192.168.1.33:8080/hessian/MenuServiceWS, interface=myapp.common.IMenuService
Seems that Service on server-side is running (the ip-address is localhost).
2.) on client-side, the code in my Activator look like this:
Register.remoteProxy(IMenuService.class).usingUrl("http://localhost:8080/hessian/MenuServiceWS")
.withProtocol("hessian").andStart(context);
RemoteClientTest rct = new RemoteClientTest();
Inject.service(IMenuService.class).into(rct).andStart(context);
rct.test();
The class RemoteClientTest looks like this:
public class RemoteClientTest {
private IMenuService menuService;
public void bind(IMenuService menuService) {
this.menuService = menuService;
public void unbind(IMenuService menuService) {
System.out.println("remoteclientest: menu service unbound"); //$NON-NLS-1$
this.menuService = null;
public void test() {
System.out.println("remoteclienttest: customer service bound"); //$NON-NLS-1$
List<EbpMenu> searchResult = menuService.getRootNodes(); //$NON-NLS-1$
for (EbpMenu m : searchResult) {
System.out.println(m.getText()); //$NON-NLS-1$
When I start the client (server is already running), i can see the following warning in the console:
Wed Sep 23 21:57:25 CEST 2009 WARNING [main] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory no IRemoteServiceFactory extension available protocol [hessian] id [myapp.common.IMenuService]
... and finally in rct.test() i'm getting the following error:
java.lang.RuntimeException: LazyProxy: missing IRemoteServiceFactory to create proxy for protocol=hessian url=http://localhost:8080/hessian/MenuServiceWS interface=myapp.common.IMenuService
I'm missing something, but i can't figure out what that is.
Can anybody help me?
Thanks in advance
Jens
Re: Problem accessing remote service [message #487666 is a reply to message #487633] |
Thu, 24 September 2009 05:00 |
Stefan Liebig Messages: 124 Registered: July 2009 |
Hi Jens,
Is the bundle org.eclipse.riena.communication.factory.hessian on your
"classpath"?
Tschüß,
Stefan
jens.mayer1@gmx.de wrote:
> console-output:
> Inject.service(IMenuService.class).into(rct).andStart(contex t);
> rct.test();
> //$NON-NLS-1$
> //$NON-NLS-1$
> //$NON-NLS-1$
> Thanks in advance
> Jens
Re: Problem accessing remote service [message #487764 is a reply to message #487666] |
Thu, 24 September 2009 11:17 |
Hi Stefan,
you're right - I added that bundle in my launch configuration to the plugin dependencies. Now everything is working fine.
Many thanks und tschüss,
Jens
Stefan Liebig wrote on Thu, 24 September 2009 01:00 | Hi Jens,
"classpath"?
Tschüß,
Stefan
> console-output:
> rct.test();
> //$NON-NLS-1$
> //$NON-NLS-1$
> //$NON-NLS-1$
> Thanks in advance
> Jens
Re: Problem accessing remote service [message #583565 is a reply to message #487666] |
Hi Stefan,
Jens
> Hi Jens,
> "classpath"?
> Tschüß,
> Stefan
> > Hi,
> > console-output:
> > rct.test();
> > //$NON-NLS-1$
> > //$NON-NLS-1$
> > //$NON-NLS-1$
> > Thanks in advance
> > Jens
Current Time: Fri Apr 19 01:12:10 GMT 2024
Powered by FUDForum. Page generated in 0.02610 seconds
