Home » Archived » OHF » set effectiveTime??
set effectiveTime?? [message #49422] Wed, 05 November 2008 10:32 Go to next message
RobertHua is currently offline RobertHuaFriend
Member
<effectiveTime xsi:type="IVL_TS">
<low value="20000328"/>
</effectiveTime>
<effectiveTime xsi:type="PIVL_TS" operator="A">
<period value="24" unit="h"/>
</effectiveTime>
How to set the format above?I can set the format:
<effectiveTime>
</effectiveTime>
Thanks!
Re: set effectiveTime?? [message #49452 is a reply to message #49422] Thu, 13 November 2008 21:56 Go to previous message
No real name is currently offline No real nameFriend
Hi Robert,
I'm not even sure how you'd get these. The only thing I can think of is
that the places in the document where these are have a generic type
(that is a type in the schema that is later extended to create IVL_TS
and PIVL_TS). So, you create an instance of one of these types and then
send that as the value to the method setEffectiveTime(...).
That's my best guess, given this limited context.
- sarah
> </effectiveTime>
> </effectiveTime>
> <effectiveTime>
> </effectiveTime>
> Thanks!
Re: set effectiveTime?? [message #588041 is a reply to message #49422] Thu, 13 November 2008 21:56 Go to previous message
Hi Robert,
- sarah
> </effectiveTime>
> </effectiveTime>
> <effectiveTime>
> </effectiveTime>
> Thanks!
Previous Topic:set effectiveTime??
Next Topic:Problem with PDQ Query - search patient by ID
Current Time: Fri Nov 27 04:11:17 GMT 2020
Powered by FUDForum. Page generated in 0.01953 seconds
