Home » Eclipse Projects » GEF » TextFlow and FlowPage producing ugly-cropped texts
TextFlow and FlowPage producing ugly-cropped texts [message #486943] |
Mon, 21 September 2009 09:09 |
Johannes Michler Messages: 21 Registered: July 2009 |
where implementing a tool using GEF. For drawing some labels, we've
implemented the following Figure:
public class PetriNetLabelFigure extends Figure {
private TextFlow textFlow;
private FlowPage flowPage;
public PetriNetLabelFigure() {
setBackgroundColor(ColorConstants.tooltipBackground);
setForegroundColor(ColorConstants.tooltipForeground);
flowPage = new FlowPage();
textFlow = new TextFlow();
textFlow.setLayoutManager(new ParagraphTextLayout(textFlow,
ParagraphTextLayout.WORD_WRAP_SOFT));
flowPage.add(textFlow);
setLayoutManager(new StackLayout());
add(flowPage);
This works so far, except for 2 problems:
1) While zooming, with some text-lengths in the flowPage (we're setting
these using textFlow.setText) and some zoom-levels, the last character of
the text gets truncated. I consider this a bug, so we posted this under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=288745
2) When changing the windows font-size from 96 dpi to 120 dpi and opening my
drawings, the text gets truncated very ugly. Is there a way to make TextFlow
and FlowPage independent of the windows "font-size" (set unter
system-display-advanced) ? This problems makes GEF nearly unusable in our
context, since having different dpi-settings is commonly used here.
Is there a better way to format a label with automatic word-wrap? It would
be great if our drawings would look the same when getting openend again. Can
I do some manual scaling? Any hints?
http://dev.eclipse.org/newslists/news.eclipse.platform.swt/m sg23152.html
seems to have the same problems, but there is no solution given over there
-orgler
Re: TextFlow and FlowPage producing ugly-cropped texts [message #487123 is a reply to message #486943] |
Tue, 22 September 2009 02:52 |
Originally posted by: robinkirk.bigfoot.com
Johannes wrote:
Hey, I had the same issue, i got around it by sublassing TextFlow and
overriding paintFigure(), and increasing the clip area based on the zoom
level, using graphics.setClip() and graphics.getAbsoluteScale(). The
text will paint outside the figures bounds, but it achieved the desired
result and text is not trimmed. I would also like a correct solution if
anyone has one.
> add(flowPage);
> of the text gets truncated. I consider this a bug, so we posted this
> under https://bugs.eclipse.org/bugs/show_bug.cgi?id=288745
> opening my drawings, the text gets truncated very ugly. Is there a way
> to make TextFlow and FlowPage independent of the windows "font-size"
> (set unter system-display-advanced) ? This problems makes GEF nearly
> unusable in our context, since having different dpi-settings is commonly
> used here.
> would be great if our drawings would look the same when getting openend
> again. Can I do some manual scaling? Any hints?
> there :-(
> -orgler
Re: TextFlow and FlowPage producing ugly-cropped texts [message #487473 is a reply to message #487123] |
Wed, 23 September 2009 11:30 |
Hi robin,
thanks for your quick reply. Could you provide me some code? I don't really
understand the code in the paintFigure() method so I'm running into problems
when trying to implement your hints :-(
-Johannes
"robin kirk" <robinkirk@bigfoot.com> schrieb im Newsbeitrag
news:h99e5j$3fe$1@build.eclipse.org...
> level, using graphics.setClip() and graphics.getAbsoluteScale(). The text
> will paint outside the figures bounds, but it achieved the desired result
> and text is not trimmed. I would also like a correct solution if anyone
> has one.
>> Hi,
>> add(flowPage);
>> my drawings, the text gets truncated very ugly. Is there a way to make
>> TextFlow and FlowPage independent of the windows "font-size" (set unter
>> there :-(
>> -orgler
Re: TextFlow and FlowPage producing ugly-cropped texts [message #487928 is a reply to message #487473] |
Thu, 24 September 2009 21:20 |
Johannes wrote:
> Hi robin,
> really understand the code in the paintFigure() method so I'm running
> into problems when trying to implement your hints :-(
protected void paintFigure(Graphics graphics) {
//set the larger clip region
graphics.setClip(getBounds().getCopy().resize((int)(graphics .getAbsoluteScale()*3),0));
super.paintFigure(graphics);
> -Johannes
>> zoom level, using graphics.setClip() and graphics.getAbsoluteScale().
>> The text will paint outside the figures bounds, but it achieved the
>> desired result and text is not trimmed. I would also like a correct
>> solution if anyone has one.
>>> Hi,
>>> add(flowPage);
>>> setting these using textFlow.setText) and some zoom-levels, the last
>>> character of the text gets truncated. I consider this a bug, so we
>>> posted this under https://bugs.eclipse.org/bugs/show_bug.cgi?id=288745
>>> way to make TextFlow and FlowPage independent of the windows
>>> "font-size" (set unter system-display-advanced) ? This problems makes
>>> GEF nearly unusable in our context, since having different
>>> openend again. Can I do some manual scaling? Any hints?
>>> there :-(
>>> -orgler
Current Time: Tue Apr 23 18:00:08 GMT 2024
Powered by FUDForum. Page generated in 0.03122 seconds
