About SWT Examples Source File [message #486774] |
Sun, 15 February 2009 21:06  |
I have downloaded eclipse-examples-3.4.1-win32.zip and found no source
file in this package.
There is no org.eclipse.sdk.examples.source_<version>/src or
swtexamplessrc.zip at all. Is there anyone know how to get the source
files of eclipse example (including SWT example source files)?
Re: About SWT Examples Source File [message #562339 is a reply to message #486774] |
Sun, 15 February 2009 22:25  |
Hi Guo Yang,
The Examples Project doesn't maintain those examples, but I'll still try
to answer your question.
I just downloaded the file you've indicated, and the sources are there.
They are included as plug-ins themselves. If you actually install the
examples into your Eclipse environment, you'll be able to browse the
code directly.
If you'd rather not install the example plug-ins, you can instead look
for the files in the "plugins" directory that contain "source" in their
name.
Alternatively, you can get the sources directly from CVS. Let me know if
you want to go this route.
HTH,
Wayne
Re: About SWT Examples Source File [message #569877 is a reply to message #486775] |
Fri, 16 October 2009 18:11  |
Hey Wayne,
I ran into the same problem as Guo Yang.
And I still cant find them.
My plugins folder for example does not contain any .java files. And even if I open the folder \org.eclipse.sdk.examples_3.1.200.v 20080612\ ...nothing there :(
FUDForum. Page generated in 0.03530 seconds
