Using the RCP runtime download [message #486067] |
Wed, 16 September 2009 04:32  |
Hi all.
I've build my application inside the development environment, and
everything went ok.
Now, I want to use an external RCP runtime.
I set the target runtime to my external RCP runtime, but the
org.eclipse.ui.views.properties.PropertyDescriptor can't be found...
Is there a place where I can download the single eclipse plugins I need?
Or, should I take them from my development environment?
Massimiliano
Re: Using the RCP runtime download [message #486421 is a reply to message #486313] |
Thu, 17 September 2009 11:01   |
All the plugins are in your development environment. The RCP binary
distribution is very minimal. In the run configuration of the product you
are trying to build, you should see what plugins are present in the binary,
and one approach is then to simply copy the required missing plugins from
- Mike
On 9/17/09 2:49 AM, in article h8stcv$occ$1@build.eclipse.org, "Massimiliano
Ziccardi" <massimiliano.ziccardi@gmail.com> wrote:
> I guess this is a VERY common problem...
> No-one has any idea?
> Let me know if you need more info.
> Thanks.
> Massimiliano Ziccardi wrote:
>> Hi all.
>> everything went ok.
>> Thanks,
>> Massimiliano
FUDForum. Page generated in 0.06202 seconds
