Home » Eclipse Projects » Buckminster dev » [buckminster-dev] syntax of buckminster import command
Re: [buckminster-dev] syntax of buckminster import command [message #485806 is a reply to message #485803] |
Tue, 15 September 2009 07:02 |
Hi Ted,
The importtargetdefinition and import are two different commands. The former imports an Eclipse Target Definition (i.e.
a .target file) and the latter imports a Buckminster CQUERY, BOM, or MSPEC.
Thomas Hallgren
On 09/15/2009 08:46 AM, Ted Kubaska wrote:
> Reading 0.6 ... page 211 ... syntax of import command ...why is it not
> the same that I see on command line.
> Book:
> importtargetdefinition [ { -? | --help } ]
> [ { -A | --active } ]
> «url or path»
> Command LIne:
> tomcat> ./buckminster import --help
> Missing BOM URL
> Help text for org.eclipse.buckminster.core.import:This command will
> populate the workspace from a Bill of Materials (BOM)
> usage: import
> [{ -? | --help }]
> [{ -C | --continueonerror}]
> [{ -T | --template }<template workspace> ]
> <url_or_path>
> .......... details also show a -D, -B, -P, and -N
Re: [buckminster-dev] syntax of buckminster import command [message #485961 is a reply to message #485803] |
Tue, 15 September 2009 17:16 |
Ted Kubaska Messages: 10 Registered: July 2009 |
Thanks ... the import I see with the --help on the command line ...
is this then the import (resolve) on page 206.
import [ { -? | --help } ]
[ { -B | --bomfile } «filename» ]
[ -C | --continueonerror ]
[ { -D | --define } «key» [ =«value» ] ]
[ { -P | --properties } «url or path» ]
[ { -t | --template } «template workspace» ]
«url or path»
which like the command line help has a -C but has a -t not a -T and
other options like -B, -D, and -P.
Bsically, trying to understand this line in one of our Hudson jobs
with the Buckminster plugin.
import ${WORKSPACE}/org.eclipse.ecf.platform.mspec
-ted
On Tue, Sep 15, 2009 at 12:02 AM, Thomas Hallgren <thomas@tada.se> wrote:
> Hi Ted,
> imports an Eclipse Target Definition (i.e. a .target file) and the latter
> Regards,
> Thomas Hallgren
>> Book:
>> «url or path»
>> Command LIne:
>> Missing BOM URL
>> usage: import
>> [{ -? | --help }]
>> <url_or_path>
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
-Ted
Re: [buckminster-dev] syntax of buckminster import command [message #486099 is a reply to message #485961] |
Wed, 16 September 2009 10:58 |
Johannes Utzig Messages: 329 Registered: July 2009 |
Hi Ted,
I'm not sure I understand your question. This will simply start the
import operation (as described in the Bucky Book on the page you
mentioned) on the given mspec in the root of the workspace of the hudson
job.
Johannes
> «url or path»
> -ted
>> Hi Ted,
>> Regards,
>> Thomas Hallgren
>>> Book:
>>> «url or path»
>>> Command LIne:
>>> Missing BOM URL
>>> usage: import
>>> [{ -? | --help }]
>>> <url_or_path>
Re: [buckminster-dev] syntax of buckminster import command [message #486189 is a reply to message #486099] |
Wed, 16 September 2009 16:01 |
Thanks. Sorry, Johannes, for the confusion .. I don't think this is
very important. What I was trying to point out was that
the description of import in the book shows options -?,-B, -C, -D. -P, and -t
the online help for import shows options -D, -P, -B, -C, -N, -T (-N is
extra) but its usage (which appears before the list of options) shows
only -?, -C, and -t (lower case as opposed to list details and book).
On Wed, Sep 16, 2009 at 3:58 AM, Johannes Utzig <mail@jutzig.de> wrote:
> Hi Ted,
> I'm not sure I understand your question. This will simply start the import
> operation (as described in the Bucky Book on the page you mentioned) on the
> given mspec in the root of the workspace of the hudson job.
> Best regards,
> Johannes
>> «url or path»
>> -ted
>>> Hi Ted,
>>> former
>>> Regards,
>>> Thomas Hallgren
>>>> Book:
>>>> «url or path»
>>>> Command LIne:
>>>> Missing BOM URL
>>>> usage: import
>>>> [{ -? | --help }]
>>>> <url_or_path>
-Ted
Re: [buckminster-dev] syntax of buckminster import command [message #486217 is a reply to message #486189] |
Wed, 16 September 2009 18:59 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
Greatful if this could be logged as a bugzilla issue against Buckminster
> Documentation so we can resolve where the issue is (the command, its
helpfile, or the book).
- henrik
Current Time: Thu Apr 25 05:22:27 GMT 2024
Powered by FUDForum. Page generated in 0.04696 seconds
