Home » Archived » IMP » Toggle comment behavior in LPG editor
Re: Toggle comment behavior in LPG editor [message #485945 is a reply to message #485543] |
Tue, 15 September 2009 15:23 |
Robert M. Fuhrer Messages: 294 Registered: July 2009 |
Brian Payton wrote:
> Here's a minor fit'n'finish item I came across in the LPG source editor.
Thanks for the report!
> In the editor, the "Toggle comment" action (Ctrl+/) adds LPG comments in
> a way that is kind of ugly. Let's say you have a rule like this:
> col_expr_cl ::=
> col_expr_spec
> | col_expr_cl , col_expr_spec
> The toggle comment action does this:
> -- col_expr_cl ::=
> -- col_expr_spec
> -- | col_expr_cl , col_expr_spec
> The equivalent action in the Java editor works a little differently. If
> you toggle comments on this:
> if (uniqueOpt != null) {
> index.setUnique(true);
> you get this:
> // if (uniqueOpt != null) {
> // index.setUnique(true);
> which I think makes it easier to spot sections of code that are
> commented out.
You're right; the present heuristic - to place the line comment prefix
just before the first non-whitespace character only works well if all
the lines in question have the same indentation, e.g.:
int x, y;
x = 15;
y++;
becomes:
// int x, y;
// x = 15;
// y++;
But as you saw, the heuristic fails when the lines don't all have the
same indentation.
By the way, this isn't a problem just for LPG; this is what the IMP
runtime support for toggling comments does.
We can do either of two things:
1) Just insert the line comment start at the very beginning of the
line (as shown above).
2) Find the common whitespace prefix of all the lines in question
and insert just after that. That would produce instead:
// int x, y;
// x = 15;
// y++;
Comments? (No pun intended)
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Toggle comment behavior in LPG editor [message #486244 is a reply to message #485945] |
Wed, 16 September 2009 21:04 |
Brian Payton Messages: 154 Registered: July 2009 |
I kind of like the common whitespace prefix approach. That's more like
I might do if I was commenting out by hand, and the commented-out code
doesn't stick out TOO much from the code around it.
>> in a way that is kind of ugly. Let's say you have a rule like this:
>> col_expr_cl ::=
>> col_expr_spec
>> -- col_expr_cl ::=
>> -- col_expr_spec
>> If you toggle comments on this:
>> you get this:
>> commented out.
> int x, y;
> x = 15;
> y++;
> becomes:
> // int x, y;
> // x = 15;
> // y++;
> same indentation.
> // int x, y;
> // x = 15;
> // y++;
Re: Toggle comment behavior in LPG editor [message #488408 is a reply to message #486244] |
Mon, 28 September 2009 14:43 |
Thanks for the feedback! Anyone else want to voice their vote?
>>> col_expr_cl ::=
>>> col_expr_spec
>>> -- col_expr_cl ::=
>>> -- col_expr_spec
>>> you get this:
>>> commented out.
>> int x, y;
>> x = 15;
>> y++;
>> becomes:
>> // int x, y;
>> // x = 15;
>> // y++;
>> same indentation.
>> // int x, y;
>> // x = 15;
>> // y++;
-- Bob
Robert M. Fuhrer
Re: Toggle comment behavior in LPG editor [message #488518 is a reply to message #488408] |
Tue, 29 September 2009 04:52 |
Ed Willink Messages: 7655 Registered: July 2009 |
I abstain; I'm not convinced either is better.
Perhaps a preference option.
Ed Willink
>> like I might do if I was commenting out by hand, and the commented-out
>> code doesn't stick out TOO much from the code around it.
>>>> editor.
>>>> comments in a way that is kind of ugly. Let's say you have a rule
>>>> like this:
>>>> col_expr_cl ::=
>>>> col_expr_spec
>>>> -- col_expr_cl ::=
>>>> -- col_expr_spec
>>>> differently. If you toggle comments on this:
>>>> you get this:
>>>> commented out.
>>> int x, y;
>>> x = 15;
>>> y++;
>>> becomes:
>>> // int x, y;
>>> // x = 15;
>>> // y++;
>>> same indentation.
>>> // int x, y;
>>> // x = 15;
>>> // y++;
Re: Toggle comment behavior in LPG editor [message #576576 is a reply to message #485543] |
> col_expr_cl ::=
> col_expr_spec
> -- col_expr_cl ::=
> -- col_expr_spec
> you get this:
> commented out.
int x, y;
x = 15;
y++;
becomes:
// int x, y;
// x = 15;
// y++;
same indentation.
// int x, y;
// x = 15;
// y++;
-- Bob
Robert M. Fuhrer
Re: Toggle comment behavior in LPG editor [message #576597 is a reply to message #485945] |
>> col_expr_cl ::=
>> col_expr_spec
>> -- col_expr_cl ::=
>> -- col_expr_spec
>> you get this:
>> commented out.
> int x, y;
> x = 15;
> y++;
> becomes:
> // int x, y;
> // x = 15;
> // y++;
> same indentation.
> // int x, y;
> // x = 15;
> // y++;
Re: Toggle comment behavior in LPG editor [message #576661 is a reply to message #486244] |
>>> col_expr_cl ::=
>>> col_expr_spec
>>> -- col_expr_cl ::=
>>> -- col_expr_spec
>>> you get this:
>>> commented out.
>> int x, y;
>> x = 15;
>> y++;
>> becomes:
>> // int x, y;
>> // x = 15;
>> // y++;
>> same indentation.
>> // int x, y;
>> // x = 15;
>> // y++;
-- Bob
Robert M. Fuhrer
Re: Toggle comment behavior in LPG editor [message #576675 is a reply to message #488408] |
Ed Willink
>>>> editor.
>>>> like this:
>>>> col_expr_cl ::=
>>>> col_expr_spec
>>>> -- col_expr_cl ::=
>>>> -- col_expr_spec
>>>> you get this:
>>>> commented out.
>>> int x, y;
>>> x = 15;
>>> y++;
>>> becomes:
>>> // int x, y;
>>> // x = 15;
>>> // y++;
>>> same indentation.
>>> // int x, y;
>>> // x = 15;
>>> // y++;
Current Time: Wed Apr 24 21:12:24 GMT 2024
Powered by FUDForum. Page generated in 0.03700 seconds
