Use Ridgets without the UI concept [message #485304] |
Fri, 11 September 2009 09:42 |
Originally posted by: eclipsixusenet.mmartl.dfgh.net
I am currently trying to setup an eclipse RCP application that has the
normal Eclipse look but is using Riena under the hood.
I am currently trying to build a view which is using Rienas ridgets.
I have created a View that extends SubModuleView<MyController> and
MyController extends SubModuleController
I have started to use this in the normal Riena UI and it worked like a
charm in there.
But now I am having problems to have the Ridget and the Widgets in the
View to work together after I have changed my application class to
startup a normal eclipse RCP application.
Can somebody tell me what I have to do so the Ridgets can be used in a
normal eclipse application?
Thanks!
Michael
Re: Use Ridgets without the UI concept [message #485307 is a reply to message #485305] |
Fri, 11 September 2009 09:56 |
Christian Campo schrieb:
> Hi Michael,
> (why do you want something that doesnot work like a charm :-) )
> Ok seriously, there is a sample that shows just that. Its the project
> org.eclipse.riena.sample.app.client.rcpmail with the launcher "Mail
> Sample (RCP UI)" that does exactly that. In
> org.eclipse.riena.sample.snippets there are also many snippets that show
> how to use Ridgets without the navigation concept....
Cool, thanks for the fast reply.
Have a nice weekend!
Michael Huber
Re: Use Ridgets without the UI concept [message #583443 is a reply to message #485305] |
> Hi Michael,
Michael Huber
FUDForum. Page generated in 0.03348 seconds
