Home » Archived » Maven Integration (M2E) » Maven dependencies?
Maven dependencies? [message #485091] Thu, 10 September 2009 13:38 Go to next message
Originally posted by: ddd.asd.com
I am trying to create a Maven module that contains a Eclipse PDE project. I
therefore need the following imports:
import org.eclipse.core.commands.AbstractHandler;
import org.eclipse.core.commands.ExecutionEvent;
import org.eclipse.core.commands.ExecutionException;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.handlers.HandlerUtil;
import org.eclipse.jface.dialogs.MessageDialog;
I have found jface:
<dependency>
<groupId>swt</groupId>
<artifactId>jface</artifactId>
<version>3.0m8</version>
</dependency>
from a site. But how do I get the other dependencies in Maven? I cannot find
them using the build in dependency manager.
Re: Maven dependencies? [message #485162 is a reply to message #485091] Thu, 10 September 2009 16:41 Go to previous messageGo to next message
Igor Fedorenko is currently offline Igor FedorenkoFriend
Have a look at Tycho project [1], which provides set of Maven extensions
and plugins to build PDE projects with Maven. In particular, look at
sample application that shows P2-based target platform resolver.
[1] https://docs.sonatype.org/display/M2ECLIPSE/Tycho+project+ov erview
[2]
https://docs.sonatype.org/display/M2ECLIPSE/Tycho+build+targ et+platform+management
Igor
> project. I therefore need the following imports:
> I have found jface:
> <dependency>
> </dependency>
> find them using the build in dependency manager.
Re: Maven dependencies? [message #485179 is a reply to message #485162] Thu, 10 September 2009 17:58 Go to previous messageGo to next message
Ok maybe I am missing the big picture here. In the PDE example an
application is created that uses the following imports:
To do this the following dependencies are defined in the MANIFEST.MF file:
org.eclipse.ui (3.5.0)
org.eclipse.core.runtime (3.5.0)
So basically as I understand it should just be a matter of defining those
dependencies in the pom.xml file, end of story.
Why go to greater lengths than this?
"Igor Fedorenko" <igor@ifedorenko.com> wrote in message
news:h8ba6t$n4f$1@build.eclipse.org...
> [2]
> Regards,
> Igor
>> I have found jface:
>> <dependency>
>> </dependency>
Re: Maven dependencies? [message #485184 is a reply to message #485162] Thu, 10 September 2009 18:21 Go to previous messageGo to next message
I can't install Tycho based on your tutorial:
http://docs.codehaus.org/display/M2ECLIPSE/tycho+technology+ demo+script
I just get:
c:\tychodemo>c:\tycho\bin\mvn
org.codehaus.tycho:maven-tycho-plugin:generate-poms -DgroupId=tycho.demo -Dtycho.targetPlatform=C:\Programs\ecl
ipse-galileo
[INFO] Build target platform
tycho.targetPlatform=C:\Programs\eclipse-galileo
.. This overrides target platform specified in pom.xml files, if any.
[INFO] Using mirror: test for repository: forge
(mirror url: http://test:8081/test/content/groups/public)
[INFO] Using mirror: test for repository: central
[ERROR]
Cannot find mojo descriptor for:
'org.codehaus.tycho:maven-tycho-plugin:generate-poms' - Treating as
non-aggregator.
[INFO] ------------------------------------------------------------ ------------
[INFO] For more information, run with the -e flag
[INFO] BUILD FAILED
[INFO] Total time: 5 seconds
[INFO] Finished at: Thu Sep 10 20:15:41 CEST 2009
[INFO] Final Memory: 9M/16M
c:\tychodemo>
any ideas?
> [2]
> Regards,
> Igor
>> I have found jface:
>> <dependency>
>> </dependency>
Re: Maven dependencies? [message #485185 is a reply to message #485184] Thu, 10 September 2009 18:33 Go to previous messageGo to next message
You likely have mirrorOf=* or mirrirOf=external:* in your settings.xml.
Ublock repo with id=forge (defined in tycho global settings.xml) using
!forge in mirrorOf or remove the mirror completely.
Igor
> I just get:
> ipse-galileo
> [ERROR]
> non-aggregator.
> [INFO]
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
> [INFO]
> c:\tychodemo>
> any ideas?
>> extensions and plugins to build PDE projects with Maven. In
>> particular, look at sample application that shows P2-based target
>> platform resolver.
>> [2]
>> Regards,
>> Igor
>>> I have found jface:
>>> <dependency>
>>> </dependency>
>>> cannot find them using the build in dependency manager.
Re: Maven dependencies? [message #485188 is a reply to message #485179] Thu, 10 September 2009 18:50 Go to previous messageGo to next message
In short, there is no universally correct mapping between Maven and
OSGi/Eclipse dependencies.
Transitive resolution works differently. OSGi import/export package and
classpath visibility rules have no analog in Maven at all. To name a
couple of differences. Besides, dependencies defined both in pom.xml and
manifest.mf will be quite laborious to keep in sync for lager projects.
Igor
> those dependencies in the pom.xml file, end of story.
>> platform resolver.
>> [2]
>> Regards,
>> Igor
>>> I have found jface:
>>> <dependency>
>>> </dependency>
Re: Maven dependencies? [message #485189 is a reply to message #485188] Thu, 10 September 2009 18:51 Go to previous messageGo to next message
Ok so first step is to make the TychoDemo work and then somehow use Thycho
to solve dependencies between the MANIFEST.MF file and the pom.xml file?
news:h8bhpp$lu1$1@build.eclipse.org...
> Regards,
> Igor
>> file:
>>> [2]
>>> Regards,
>>> Igor
>>>> I have found jface:
>>>> <dependency>
>>>> </dependency>
Re: Maven dependencies? [message #485226 is a reply to message #485189] Thu, 10 September 2009 20:01 Go to previous message
I would probably look at Tycho target platform management wiki [1] and
corresponding sample application [2].
[1]
[2] http://svn.sonatype.org/m2eclipse/tycho/trunk/tycho-demo/itp 01/
Igor
> Thycho to solve dependencies between the MANIFEST.MF file and the
> pom.xml file?
>> and classpath visibility rules have no analog in Maven at all. To name
>> a couple of differences. Besides, dependencies defined both in pom.xml
>> and manifest.mf will be quite laborious to keep in sync for lager
>> projects.
>> Regards,
>> Igor
>>> file:
>>>> platform resolver.
>>>> [2]
>>>> Regards,
>>>> Igor
>>>>> I have found jface:
>>>>> <dependency>
>>>>> </dependency>
Previous Topic:Writing plugin using "Plug-in Development" or a maven plugin?
Next Topic:0.9.9 release
Current Time: Wed Sep 18 19:41:04 GMT 2019
Powered by FUDForum. Page generated in 0.01822 seconds
