Re: environment variables for eclipse.ini [message #486427 is a reply to message #486377] |
Thu, 17 September 2009 15:15 |
Originally posted by: wegener.cboenospam.com
You could write a shell script/batch file to get this to work. The vm
parameter can be specified on the command line. Create a script file which
calls eclipse with a command line parameter of -vm
"%JAVA_HOME%\bin\javaw.exe". Then use the script file to run eclipse.
"Lars Fischer" <lfischer@fast-mail.org> wrote in message
news:h8tdla$trn$1@build.eclipse.org...
> Hello David,
> thank you for your answer.
> David Williams wrote:
> > Lars Fischer wrote:
> >> I would like to use windows environment variables values as parameters
> >> in the eclipse.ini. E.g. JAVA_HOME with the path to the JDK for "-vm
> >> I tried the above, but it does not work. Is there an other way how I
> >> can solve this?
> > I don't believe so, since I couldn't find it documented anywhere, and
> > tried a few tests myself.
> > But just in case you are asking "how do I get the VM at JAVA_HOME used,
> > then that part should be automatically found by the launcher.
> JAVA_HOME is only one exmple for a configuration parameter.
> I would like to define multiple settings which can differ on several
> computers and prepare ONE eclipse installation deployed to this
> computers to use the environment settings on startup. But it looks like
> this is not possible.
> Regards,
> Lars
FUDForum. Page generated in 0.08037 seconds
