Re: EclipseLink-7242 [message #486257 is a reply to message #485927] |
Wed, 16 September 2009 22:14 |
Mauro Messages: 79 Registered: July 2009 |
Member |
Doug,
I really appreciate your reply.
"I am unsure how the application would differentiate this state"
That's the backstage of openjpa. My application don't worry about it.
I made I simple example that can show the difference of behavior. It shows
the change of values in 3 scenarios traced before and after the
serialization (web context)
1)after the find and before the execution of method get of relationship
2)after the get and before the method size
3)after the size
In openjpa, if a relationship was no initialized (scenario 1) , its
serialized with null. As soon as a method getRelationship is executed its
filled with a subclass of ArrayList with 0 or more elements(scenario 2 e
3). So a null collection means that relationship was not initialized and
an empty collection means that the relationship doesn't exist.
In eclipselink, in all scenarios the relationship has an InternalList. In
scenario 1 and 2 the internal list has the property isInstantiated set to
false and throws an exception when serialized In scenario 3, the
property isInstantiated is set to true and relationship is serialized.
Eclipselink wouldn't have an configured option sinalizing to serialize
relationship as null when the property isInstatiated is set to false????
Wouldn't it be a good approach?
I'm working on a proxy (Ejb interceptor) that makes exactly this. Each
collection of a returned entity that has an InternalList not instantiated
is set to null before the serialization. I'm not sure if that's the best
approach.
Example
EJB Class:
@Stateless(mappedName = "ARN")
@TransactionAttribute(TransactionAttributeType.REQUIRED)
public class ARNImpl implements ARN {
protected final Log logger = LogFactory.getLog(getClass());
@Resource
SessionContext context;
@PersistenceContext(unitName="TESTE")
EntityManager em;
public A consultWithoutGet(int code) {
System.out.println("Code" + code);
A a = em.find(A.class, code);
return a;
public A consultWithoutSize(int code) {
List<B> listaB = a.getListB();
if (listaB == null) {
System.out.println("SessionBean Before size() - null relationship");
return a;
System.out.println("SessionBean Before size() - Class relationship: "
+ listaB.getClass().getName());
System.out.println("SessionBean Before size() - Super Class
relationship: " + listaB.getClass().getSuperclass().getName());
if (listaB instanceof IndirectList) {
System.out.println("SessionBean Before size() - Eclipselink
Instantiated: " + ((IndirectList)listaB).isInstantiated());
return a;
public A consultWithSize(int code) {
int size = a.getListB().size();
System.out.println("SessionBean After size() - null relationship");
return null;
System.out.println("SessionBean size - : " + size);
System.out.println("SessionBean After size() - Class relationship: "
System.out.println("SessionBean After size() - Super Class
System.out.println("After size() - Eclipselink Instantiated: " +
return a;
Pojo Method called from JSP that calls the EJB
public void consult() {
ARN arn = (ARN) ServiceLocator.getEJB3(ARN.class);
A a = arn.consultWithoutGet(code);
try {
if (a.getListB() != null) {
System.out.println("Web context - before get() - class " +
a.getListB().getClass().getName());
System.out.println("Web context - before get() - size " +
a.getListB().size());
} else {
System.out.println("Web context - before get() - relationship
null");
} catch (Exception e) {
System.out.println("Web context - before size() - exeption: " +
e.getClass());
try {
a = arn.consultWithoutSize(code);
System.out.println("Web context - before size() - class " +
System.out.println("Web context - before size() - size " +
} else {
System.out.println("Web context - before size() - relationship
null");
e.getClass());
try {
a = arn.consultWithSize(code);
System.out.println("Web context - after size() - class " +
System.out.println("Web context - after size() - size " +
System.out.println("Web context - after size() - exeption: " +
e.getClass());
Entity A
@Entity
@Table(name = "A")
public class A implements Serializable{
@OneToMany(fetch = FetchType.LAZY, mappedBy = "a")
private List<B> listB = new ArrayList<B>();
Running with eclipselink
org.eclipse.persistence.indirection.IndirectList
Web context - before get() - exeption: class
org.eclipse.persistence.exceptions.ValidationException
SessionBean Before size() - Super Class relationship: java.util.Vector
SessionBean Before size() - Eclipselink Instantiated: false
Web context - before size() - exeption: class
SessionBean size - : 2
SessionBean After size() - Super Class relationship: java.util.Vector
After size() - Eclipselink Instantiated: true
Web context - after size() - size 2
Running with openjpa
Web context - before get() - relationship null
org.apache.openjpa.util.java$util$ArrayList$proxy
SessionBean Before size() - Super Class relationship: java.util.ArrayList
Web context - before size() - size 2
SessionBean After size() - Super Class relationship: java.util.ArrayList
FUDForum. Page generated in 0.03865 seconds
