Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Understanding EMF Compare
[EMF Compare] Understanding EMF Compare [message #484260] Fri, 04 September 2009 21:34 Go to next message
Timothy Marc is currently offline Timothy MarcFriend
Hello all Comparer,
i'm a newbie to EMF Compare and i want to understand this great stuff. I
have a model with four elements
Element:Root
PrimitiveType{name=Integer}
PrimitiveType{name=Real}
PrimitiveType{name=Boolean}
PrimitiveType{name=String}
Than, i create another similiar model like this
Element:Root
PrimitiveType{name=Double}
Only the Real value changed to Double. After merging these two models,
the resulting models is exactly the second model. I've introspected the
DiffModel and a Update difference was detected.
What i want the merge algorithm to do is to copy the new double
primitive type into the existing model, so that five primitive types are
contained in the root instead of four. So, for me a general questions
has raised:
Is it possible to build the diff of these two models and than just copy
the missing elements into the left model? I didn't want to get the
models merged entiredly in the end.
And how did EMF Compare indicated that two instances are "equal"?
Thx
Timothy
Re: [EMF Compare] Understanding EMF Compare [message #484363 is a reply to message #484260] Mon, 07 September 2009 08:26 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------010804070507030201020103
Hi Timothy,
In the case described, there is no way to discriminate between two
elements other than through their name attribute. Between "Real" and
"Double" I
Re: [EMF Compare] Understanding EMF Compare [message #621357 is a reply to message #484260] Mon, 07 September 2009 08:26 Go to previous message
Hi Timothy,
"Double" I
Previous Topic:[EMF Compare] Understanding EMF Compare
Next Topic:[EMF Compare] resourceURISimilarity fails with empty URI
Current Time: Wed Apr 24 22:21:05 GMT 2024
Powered by FUDForum. Page generated in 0.02478 seconds
