Variable that point to webapps directory? [message #484170] |
Fri, 04 September 2009 13:45 |
Originally posted by: david.balazic.hermes.si.foo
Hi!
In a (web app) project we have this line in the project.properties file:
something=F:/work/eclipseWS/ws1/.metadata/.plugins/org.eclip se.wst.server.core/tmp0/webapps/
That is obviously not a good thing. Is there some variable we could use?
A variable that point to the tomcat webapp directory?
We use Eclipse 3.5.0 and Tomcat 6.0 (configured as server in Eclipse).
David
PS: We inherited this project from others, so don't blame us ;-)
My email address has a spamers-confusing addition...
Re: Variable that point to webapps directory? [message #484299 is a reply to message #484195] |
Sat, 05 September 2009 19:57 |
Originally posted by: david.balazic.hermes-softlab.com.foo
(I'm not at th PC with the right now, so...)
... I think it is used in a maven "script", that is a maven XML file.
(I will give more accurate info on monday)
David
Larry Isaacs wrote:
> Finding a better alternative is very much dependent on the exact purpose
> of this setting and what is using it. For example, is it being used in
> an Ant script?
> Cheers,
> Larry
> David BalaÅŸic wrote:
>> Hi!
>> Thanks,
>> David
Re: Variable that point to webapps directory? [message #484367 is a reply to message #484195] |
Mon, 07 September 2009 09:22 |
It is used in maven, for example
<copy file="some.file" todir="${something}" />
David
> an Ant script?
> Cheers,
> Larry
> David Balažic wrote:
>> Hi!
>> Thanks,
>> David
Re: Variable that point to webapps directory? [message #484614 is a reply to message #484367] |
Tue, 08 September 2009 14:05 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
I'm not aware of the WTP Tomcat support making something like this
available within the Eclipse environment. You may have to look in the
maven support to see if they provide a way of defining substitution
variables. Not knowing much about the maven support, I don't know if
substitution variables defined within Eclipse would be visible when
maven runs.
Also, copying files to the "webapps" folder suggests that maven's
support for Tomcat is independent of WTP's built-in support for Tomcat,
which publishes to a "wtpwebapps" folder. I can't predict how well they
will work together.
You do have the option of setting the "catalina.base" directory to
something less "internal" than
".metadata/.plugins/org.eclipse.wst.server.core/tmp0". Remove any
projects from the server and publish the server. Then double-click the
Tomcat server in the Servers view to open the server editor. Select
"Use custom location" in the Server Locations section, and specify
something suitable for "Server path".
Larry
> Regards,
> David
>> purpose of this setting and what is using it. For example, is it
>> being used in an Ant script?
>> Cheers,
>> Larry
>>> Hi!
>>> Thanks,
>>> David
Re: Variable that point to webapps directory? [message #484638 is a reply to message #484614] |
Tue, 08 September 2009 14:15 |
Thanks.
But closer inspection reveals that this might be no necessary at all.
It is used to copy the webapp war file to the tomcat webapps dir, but
eclipse takes care if deployment automatically.
But I am new on the project, maybe this is needed anyway ...
David
> maven runs.
> will work together.
> Cheers,
> Larry
>> Regards,
>> David
>>> Cheers,
>>> Larry
>>>> Hi!
>>>> file:
>>>> use?
>>>> Thanks,
>>>> David
FUDForum. Page generated in 0.03398 seconds
