Home » Archived » Service Oriented Architecture Tools Platform (STP) » SVN access.
SVN access. [message #484117] |
Fri, 04 September 2009 11:26 |
Juan Pedro Silva Messages: 258 Registered: July 2009 |
--------------080305040008020804040105
Hello everybody. I'm trying to access the SVN to check out the
org.eclipse.stp.xef.test fragment for the policy editor, but cannot
access the repository.
In the STP web it says that you can access either, and I quote:
/*svn+ssh://dev.eclipse.org/svnroot/stp* Anonymous read-access is
enabled at http://dev.eclipse.org/svnroot/stp for those who want to view
to code, committers should log in to make changes./
I tried both with no luck. the svn+ssh doesn't take Anonymous/Anonymous,
Anonymous/"", or my bugzilla username/password.
The http(s) or svn (without ssh) repositories are not even found.
I see that now the repository is split, and in the viewcvs the new
address is
http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?root=STP_POLICYEDITOR
but I couldn't access that repository either.
How should I currently acces the respository?.
Thank you very much.
Juan Pedro
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
access the repository.<br>
In the STP web it says that you can access either, and I quote:<br>
<br>
<i><b>svn+ssh://dev.eclipse.org/svnroot/stp</b> Anonymous read-access
is enabled at <a href="http://dev.eclipse.org/svnroot/stp">http://dev.eclipse.org/svnroot/stp</a>
for those who want to view to code, committers should log in to make
changes.</i> <br>
<br>
Anonymous/Anonymous, Anonymous/"", or my bugzilla username/password.<br>
The http(s) or svn (without ssh) repositories are not even found.<br>
<br>
address is
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?root=STP_POLICYEDITOR"> http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?root=STP_POLICYEDITOR</a><br>
but I couldn't access that repository either.<br>
<br>
How should I currently acces the respository?.<br>
Thank you very much.<br>
Regards,<br>
Juan Pedro<br>
</body>
</html>
--------------080305040008020804040105--
Re: [stp-newsgroup] Re: SVN access. [message #484130 is a reply to message #484129] |
Fri, 04 September 2009 12:08 |
Antoine Toulmé Messages: 31 Registered: July 2009 |
Member |
--001636c5986d9ba1890472bf5b06
Content-Transfer-Encoding: quoted-printable
Juan, please file us a bug with a link to the web page where you read this
invalid information.
Antoine
On Fri, Sep 4, 2009 at 14:03, Stephane Drapeau <Stephane.Drapeau@obeo.fr>wr=
ote:
> Hi Juan Pedro,
> Access to [0] is not allowed.
> To access the policy editor repository use [1]. You can find the reposito=
ry
> locations for each STP project here: [2].
> Stephane Drapeau
> Obeo
> [0]: http://dev.eclipse.org/svnroot/stp
> [1]:
> http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.policy-ed itor/org.ecli=
pse.stp.policy
> [2]: http://wiki.eclipse.org/STP/Source_Code
> Juan Pedro Silva a =E9crit :
>> org.eclipse.stp.xef.test fragment for the policy editor, but cannot acce=
ss
>> the repository.
>> I see that now the repository is split, and in the viewcvs the new addre=
ss
>> is
>> http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?r=
oot=3DSTP_POLICYEDITOR
>> Regards,
>> Juan Pedro
> _______________________________________________
> stp-newsgroup mailing list
> stp-newsgroup@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/stp-newsgroup
Juan, please file us a bug with a link to the web page where you read this =
invalid information.<div><br></div><div>Thanks,</div><div><br ></div><div>An=
toine<br><br><div class=3D"gmail_quote">On Fri, Sep 4, 2009 at 14:03, Steph=
ane Drapeau <span dir=3D"ltr"><<a href=3D"mailto:Stephane.Drapeau@obeo.f=
r">Stephane.Drapeau@obeo.fr</a>></span> wrote:<br>
<blockquote class=3D"gmail_quote" style=3D"margin:0 0 0 .8ex;border-left:1p=
x #ccc solid;padding-left:1ex;">Hi Juan Pedro,<br>
<br>
Access to [0] is not allowed.<br>
<br>
To access the policy editor repository use [1]. You can find the repository=
locations for each STP project here: [2].<br>
<br>
Stephane Drapeau<br>
Obeo<br>
<br>
[0]: <a href=3D"http://dev.eclipse.org/svnroot/stp" target=3D"_blank">http:=
//dev.eclipse.org/svnroot/stp</a><br>
[1]: <a href=3D" http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.policy-e=
ditor/org.eclipse.stp.policy" target=3D"_blank">http://dev.eclipse.org/svnr=
oot/stp/org.eclipse.stp.policy-editor/org.eclipse.stp.policy </a><br>
[2]: <a href=3D"http://wiki.eclipse.org/STP/Source_Code" target=3D"_blank">=
http://wiki.eclipse.org/STP/Source_Code</a><br>
<br>
Juan Pedro Silva a =E9crit :<div><div></div><div class=3D"h5"><br>
x #ccc solid;padding-left:1ex">
Hello everybody. I'm trying to access the SVN to check out the org.ecli=
pse.stp.xef.test fragment for the policy editor, but cannot access the repo=
sitory.<br>
<br>
=A0/*svn+ssh://<a href=3D"http://dev.eclipse.org/svnroot/stp*" target=3D"_b=
lank">dev.eclipse.org/svnroot/stp*</a> Anonymous read-access is enabled at =
<a href=3D"http://dev.eclipse.org/svnroot/stp" target=3D"_blank">http://dev=
..eclipse.org/svnroot/stp</a> for those who want to view to code, committers=
should log in to make changes./<br>
<br>
I tried both with no luck. the svn+ssh doesn't take Anonymous/Anonymous=
<br>
I see that now the repository is split, and in the viewcvs the new address =
is <a href=3D" http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol i=
cy/trunk/?root=3DSTP_POLICYEDITOR" target=3D"_blank">http://dev.eclipse.org=
/viewsvn/index.cgi/org.eclipse.stp.policy/trunk/?root=3DSTP_ POLICYEDITOR </a=
><br>
<br>
Regards,<br>
=A0 =A0 =A0 =A0 =A0 =A0 =A0Juan Pedro<br>
</blockquote></div></div>
_______________________________________________<br>
stp-newsgroup mailing list<br>
<a href=3D"mailto:stp-newsgroup@eclipse.org" target=3D"_blank">stp-newsgrou=
p@eclipse.org</a><br>
<a href=3D"https://dev.eclipse.org/mailman/listinfo/stp-newsgroup" target=
=3D"_blank">https://dev.eclipse.org/mailman/listinfo/stp-newsgroup</a><br>
</blockquote></div><br></div>
--001636c5986d9ba1890472bf5b06--
Re: SVN access. [message #484144 is a reply to message #484129] |
Fri, 04 September 2009 12:33 |
Great, Stephane, thank you very much.
May I suggest an update of the info at the STP download page to avoid
confusion to future comers?.
Juan Pedro
Stephane Drapeau escribió:
> Hi Juan Pedro,
> repository locations for each STP project here: [2].
> Stephane Drapeau
> Obeo
> [1]:
> http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.policy-ed itor/org.eclipse.stp.policy
>> view to code, committers should log in to make changes./
>> address is
>> Regards,
>> Juan Pedro
Re: SVN access. [message #484156 is a reply to message #484144] |
Fri, 04 September 2009 13:08 |
Stephane Drapeau Messages: 199 Registered: July 2009 |
I updated the page. Thank you for reporting the bug.
Stephane Drapeau
Obeo
> Best regards,
> Juan Pedro
>> Hi Juan Pedro,
>> Stephane Drapeau
>> Obeo
>> [1]:
>>> address is
>>> Regards,
>>> Juan Pedro
Re: [stp-newsgroup] Re: SVN access. [message #621225 is a reply to message #484129] |
Member |
Antoine
ote:
> Hi Juan Pedro,
ry
> Stephane Drapeau
> Obeo
> [1]:
pse.stp.policy
ss
>> the repository.
ss
>> is
>> Regards,
>> Juan Pedro
<br>
<br>
<br>
Obeo<br>
<br>
<br>
sitory.<br>
<br>
<br>
<br>
><br>
<br>
Regards,<br>
Re: SVN access. [message #621226 is a reply to message #484129] |
Juan Pedro
> Hi Juan Pedro,
> Stephane Drapeau
> Obeo
> [1]:
>> address is
>> Regards,
>> Juan Pedro
Re: SVN access. [message #621530 is a reply to message #484144] |
Stephane Drapeau
Obeo
> Best regards,
> Juan Pedro
>> Hi Juan Pedro,
>> Stephane Drapeau
>> Obeo
>> [1]:
>>> address is
>>> Regards,
>>> Juan Pedro
Current Time: Thu Apr 18 08:22:58 GMT 2024
Powered by FUDForum. Page generated in 0.01698 seconds
