Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Why does the StyledCellLabelProvider.update() method repeat the 1st column text?
Why does the StyledCellLabelProvider.update() method repeat the 1st column text? [message #483948] |
Thu, 03 September 2009 17:42 |
Originally posted by: slocumj.vmware.com
* This class demonstrates a problem with Eclipse Gtk and SWT on Linux. By
contrast, the same exact code works fine on Windows.
* The Linux platform is: CentOS 5, GNOME 2.16.0, Eclipse RCP/Plug-in
Developers (Eclipse 3.5), Eclipse Build ID: 20090619-0625
* The Windows platform is: Windows XP SP3, Eclipse RCP/Plug-in Developers
* A simple 3-row, 3-column table is displayed in a window on the screen.
* Each cell in the table has its text set to "Row # Column #".
* On Windows, this looks like:
* Row 0 Column 0 | Row 0 Column 1 | Row 0 Column 2
* Row 1 Column 0 | Row 1 Column 1 | Row 1 Column 2
* Row 2 Column 0 | Row 2 Column 1 | Row 2 Column 2
* This is correct.
* However, on Linux, this looks like:
* Row 0 Column 0 | Row 0 Column 0 | Row 0 Column 0
* Row 1 Column 0 | Row 1 Column 0 | Row 1 Column 0
* Row 2 Column 0 | Row 2 Column 0 | Row 2 Column 0
* This is NOT correct. The text values in the first column are being
repeated in the 2nd and 3rd column.
* Why is this happening?
import org.eclipse.core.runtime.ISafeRunnable;
import org.eclipse.jface.layout.TableColumnLayout;
import org.eclipse.jface.viewers.ColumnWeightData;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.StyledCellLabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
public class ExampleProblem {
private static Display DISPLAY = Display.getDefault();
Shell shell = new Shell(DISPLAY, SWT.CLOSE | SWT.RESIZE);
shell.setSize(400, 400);
shell.setLayout(new GridLayout(1, false));
ExampleProblem example = new ExampleProblem();
Control composite = example.createPartControl(shell);
composite.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true,
true, 1, 1));
shell.open();
while (!shell.isDisposed()) {
if (!DISPLAY.readAndDispatch()) {
DISPLAY.sleep();
DISPLAY.dispose();
public ExampleProblem() {
public Composite createPartControl(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
TableColumnLayout tcLayout = new TableColumnLayout();
composite.setLayout(tcLayout);
final TableViewer tableViewer = new TableViewer(composite,
SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER);
Table table = tableViewer.getTable();
TableColumn firstColumn = new TableColumn(table, SWT.LEFT);
firstColumn.setText("First Column");
tcLayout.setColumnData(firstColumn, new ColumnWeightData(1));
TableColumn secondColumn = new TableColumn(table, SWT.LEFT);
secondColumn.setText("Second Column");
tcLayout.setColumnData(secondColumn, new ColumnWeightData(1));
TableColumn thirdColumn = new TableColumn(table, SWT.LEFT);
secondColumn.setText("Third Column");
tcLayout.setColumnData(thirdColumn, new ColumnWeightData(1));
ExampleLabelProvider labelProvider = new ExampleLabelProvider();
FileSystemContentProvider contentProvider= new
FileSystemContentProvider();
tableViewer.setContentProvider(contentProvider);
tableViewer.setLabelProvider(labelProvider);
GridData data = new GridData(GridData.FILL, GridData.FILL, true,
true);
tableViewer.getControl().setLayoutData(data);
tableViewer.setInput(new Object());
return composite;
private static class ExampleLabelProvider extends
StyledCellLabelProvider {
private static final Image IMAGE1 = new Image(DISPLAY,
DISPLAY.getSystemImage(SWT.ICON_WARNING).getImageData().scal edTo(16, 16));
private static final Image IMAGE2 = new Image(DISPLAY,
DISPLAY.getSystemImage(SWT.ICON_ERROR).getImageData().scaled To(16, 16));
public ExampleLabelProvider() {
public void update(ViewerCell cell) {
// On Linux, the second and third cells contain the text of
the first cell --> INCORRECT
// On Windows, the second and third cells contain the correct
text
// However, the image is NOT repeated on Linux or Windows
(correct behavior on both platforms)
cell.setText((String)cell.getElement() + " Column " +
cell.getColumnIndex());
if (cell.getColumnIndex() == 0) {
cell.setImage(IMAGE1);
} else if (cell.getColumnIndex() == 1) {
cell.setImage(IMAGE2);
} else {
super.update(cell);
private static class FileSystemContentProvider implements
IStructuredContentProvider {
public Object[] getElements(Object element) {
Object[] objArr = new Object[3];
for (int i = 0; i < objArr.length; i++) {
objArr[i] = "Row " + i + ": ";
return objArr;
public void dispose() {
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
Re: Why does the StyledCellLabelProvider.update() method repeat the 1st column text? [message #484007 is a reply to message #483948] |
Thu, 03 September 2009 20:42 |
Grant Gayed Messages: 2150 Registered: July 2009 |
It looks like a bug, so I've logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=288565 . I believe it's a
custom-draw problem, so if you didn't care about using custom draw in your
app then you could probably work around it by using a conventional
ITableLabelProvider implementation instead (I realize that you probably do
care about using custom draw though). I don't know of another workaround at
the moment since it's jface that ultimately draws the text.
Grant
"Justin Slocum" <slocumj@vmware.com> wrote in message
news:62b6bb33fcd11d43cbc51b6b59cb164b$1@www.eclipse.org...
> * This is correct.
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> true, 1, 1));
> shell.open();
> DISPLAY.sleep();
> DISPLAY.dispose();
> true);
> return composite;
> text
> } else {
> super.update(cell);
> return objArr;
> newInput) {
Re: Why does the StyledCellLabelProvider.update() method repeat the 1st column text? [message #484008 is a reply to message #484007] |
Thu, 03 September 2009 20:57 |
Even more weirdness:
I tried this again on Ubuntu 9.04/GNOME 2.26.1, and now I get the same
problem as before, but I noticed that when I use the mouse to re-size the
window, the text labels in the last column (column 2) flicker back and
forth between the correct value: "row...column 2" and the wrong value
"row...column 0". When I let go of the left mouse button, the value
settles to "row ... column 0" --> the incorrect value. It's like there is
a last event that is repainting the cells with the incorrect value before
returning. The correct values are buried in there somewhere.
I need to highlight or color-code certain sections of text in each cell,
so I don't think I can just use ITableLabelProvider and getColumnText() /
getColumnImage(). That is why I'm using StyledCellLabelProvider with its
update() method. Is there another way for me to highlight or color
sections of text in the cell in a Table without using
StyledCellLabelProvider ?
Thanks very much for looking into this.
Re: Why does the StyledCellLabelProvider.update() method repeat the 1st column text? [message #484628 is a reply to message #484008] |
Tue, 08 September 2009 14:20 |
I think that switching from TableViewer to using a Table instead will make
this work for you. Though your current problem is likely rooted in Table, I
think you're seeing it as a result of how TableViewer reacts to custom draw
events, which is more complex than a typical case. If you were to use a
Table and just do the drawing in response to these events then I think it
would work. For more info on using Table/Tree custom draw at the swt level
see
http://www.eclipse.org/articles/article.php?file=Article-Cus tomDrawingTableAndTreeItems/index.html .
The only other way to do this, which I would not suggest, would be to embed
Controls in the cells that are capable of drawing your content (eg.-
StyledTexts). For an example of embedding Controls in Table/Tree cells see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet149.java?view=co .
HTH,
Grant
news:72d478195a5cff27cb2ae34c50cf4e7a$1@www.eclipse.org...
Current Time: Thu Apr 18 11:45:28 GMT 2024
Powered by FUDForum. Page generated in 0.02137 seconds
