Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] possible bug comparing resources
[EMF Compare] possible bug comparing resources [message #483400] Tue, 01 September 2009 13:12 Go to next message
Jose Hernandez is currently offline Jose HernandezFriend
Member
I have encountered a problem in EMF compare whereby an index out of bounds
(-1) exception in thrown in resourceURISimilatity when comparing in memory
(non-persisted) resources. My resources are created in this way:
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(URI.createURI(""));
EList<EObject> contents = resource.getContents();
contents.add(emfModel);
Does anyone know whether this is a known issue? If so, is there are fix for
it?
java.lang.ArrayIndexOutOfBoundsException: -1
at
org.eclipse.emf.compare.match.internal.statistic.ResourceSim ilarity.resourceURISimilarity(ResourceSimilarity.java:138)
at
org.eclipse.emf.compare.match.internal.statistic.ResourceSim ilarity.computeURISimilarity(ResourceSimilarity.java:94)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.co mputeDeletedReferences(ReferencesCheck.java:400)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.cr eateNonConflictingReferencesUpdate(ReferencesCheck.java:520)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.ch eckReferenceUpdates(ReferencesCheck.java:197)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.ch eckReferencesUpdates(ReferencesCheck.java:77)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.checkF orDiffs(GenericDiffEngine.java:338)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff Delegate(GenericDiffEngine.java:930)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff Delegate(GenericDiffEngine.java:953)
at
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff TwoWay(GenericDiffEngine.java:576)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff (GenericDiffEngine.java:113)
at
org.eclipse.emf.compare.diff.service.DiffService.doDiff(Diff Service.java:101)
at
org.eclipse.emf.compare.diff.service.DiffService.doDiff(Diff Service.java:82)
Jose
Re: [EMF Compare] possible bug comparing resources [message #484469 is a reply to message #483400] Mon, 07 September 2009 15:18 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------060801030808070000010105
Hi Jose,
Sorry for not responding, I didn't pay attention to this message.
This is an overlook from our side and will be fixed in the next build.
Would be better if you had set proper URIs to your resources though, it
would tell the framework which content they hold (resource.uml would
suffice for your resource to be an "UMLResourceImpl" instead of the
regular "ResourceImpl" for example.
Laurent Goubet
Obeo
Jose Hernandez a
Re: [EMF Compare] possible bug comparing resources [message #484559 is a reply to message #484469] Tue, 08 September 2009 09:01 Go to previous message
Member
Hi Laurent,
I've given my resources names as suggested to work around the issue.
I look forward to the next release.
Jose
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:h8388u$b68$1@build.eclipse.org...
> Hi Jose,
> Laurent Goubet
> Obeo
> Jose Hernandez a
Re: [EMF Compare] possible bug comparing resources [message #621364 is a reply to message #483400] Mon, 07 September 2009 15:18 Go to previous message
Hi Jose,
Laurent Goubet
Obeo
Jose Hernandez a
Re: [EMF Compare] possible bug comparing resources [message #621367 is a reply to message #484469] Tue, 08 September 2009 09:01 Go to previous message
Member
Hi Laurent,
Jose
> Hi Jose,
> Laurent Goubet
> Obeo
> Jose Hernandez a
Previous Topic:[EMF Compare] Similarity in ordered list
Next Topic:[EMF Compare] 3 way match
Current Time: Tue Jan 21 09:36:17 GMT 2025
Powered by FUDForum. Page generated in 0.03130 seconds
