Setting editor tab dirty in EMF generated Editor [message #483198] |
Mon, 31 August 2009 14:23  |
Originally posted by: formatzeh.gmx.de
I generated a MultiPageEditor with EMF. As I wanted being able to
investigate the source of a model I added the default XML editor from
the WTP project as a tab with the following code:
StructuredTextEditor editor = new StructuredTextEditor();
editor.setEditorPart(this);
int xmlEditorIndex = addPage(editor, getEditorInput());
setPageText(xmlEditorIndex, "Source");
But if I modify something in the StructuredTextEditor tab the resource
doesn't get dirty, means that if I change something in the source tab
the * won't appear next to the resource name in the editor. How can I
achieve this? Now I have to open the resouce with right click-->open
with-->Text Editor and there the file is dirty and I can save it. But
that's annoying as you understand :) And for example if I modify
something in the source tab then the labels and all in the model tabs
should update as well. Any hints?
Re: Setting editor tab dirty in EMF generated Editor [message #483423 is a reply to message #483380] |
Tue, 01 September 2009 14:59   |
Gilbert,
The EMF editor itself determines dirtiness by virtue of the state of the
command stack. To get this all working properly, something needs to be
done to integrate the command stack of the text editor and the one being
used by the overall EMF generated editor. I have no experience with how
to do that though...
Gilbert Mirenque wrote:
> Is there an editor expert? I would like to ask this question in the EMF
> group but I think the editor issue is better asked here.
Re: Setting editor tab dirty in EMF generated Editor [message #483467 is a reply to message #483423] |
Tue, 01 September 2009 17:01   |
Ok...does someone has an idea how to achieve this?
Ed Merks wrote:
> Gilbert,
FUDForum. Page generated in 0.02792 seconds
