PDE Export and Debug Info [message #49014] |
Wed, 04 March 2009 10:06 |
Manuel Selva Messages: 189 Registered: July 2009 Location: Grenoble, France |
Hi there,
I am trying to compare class file size differences between classes with
debug info and classes without.
To do that I just change my project Java Compiler options. Looking at the
class file size generated in my plugin bin directory clearly show a
difference between classes with debug info and classes without.
My problem is that classes files always have the same size in both cases
(with or without debug info) after having exported my plug-in using
"graphical exporter" (righ click -> export as ...)
It seems PDE always export plug-ins with debug info when I export
graphically. Why ? Did I miss something ?
I know I can set javacDebugInfo=true in my headless build but I just want
to understand why graphically export doesn't behave as expected for me ...
Thanks in advance
Manu
http://manuelselva.wordpress.com/
Re: PDE Export and Debug Info [message #592713 is a reply to message #49072] |
Wed, 04 March 2009 15:41 |
Thanks for this info Chris !!!
Now I have an other problem with my headless build where changing the
build.properties file of my "build configuration" and not every
build.properties of all my plug-ins doesn't change nothing in generated
class files.
After looking at the build.xml file generated by pde all seems ok and it
seems that debug=on is passed to the javac task but .... generated classes
don't have debug informations !!!
Any ideas ?
Thanks again
Manu
FUDForum. Page generated in 0.03444 seconds
