Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Background application is getting activated.
Background application is getting activated. [message #482862] Fri, 28 August 2009 10:58 Go to next message
Raghava Rao is currently offline Raghava RaoFriend
Member
Hello All,
I created two views in workbecnappilcation.
Based on selection in first view ,Some UI controls will be created in
other view.
While switching selection between the tree items in first view,some times
Back ground application is getting activated.i.e wat ever i sthere in back
ground window gets activated.
please suggest me to avoid above behaviour.
Advance thanks for you reply.
Raghava
Re: Background application is getting activated. [message #482926 is a reply to message #482862] Fri, 28 August 2009 14:48 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
Hi Raghava,
That shouldn't happen, I don't know what swt would be doing to cause that.
Does the snippet below show the problem? And if not, can you change it to
make it show the problem? And which platform are you on?
public static void main (String [] args) {
final Display display = new Display ();
final Shell shell = new Shell (display);
shell.setLayout(new GridLayout(2, true));
// left pane
final Tree tree = new Tree(shell, SWT.NONE);
// right pane
final Composite composite = new Composite(shell, SWT.NONE);
composite.setLayout(new StackLayout());
new Label(composite, SWT.BORDER).setText("zero");
new Button(composite, SWT.PUSH).setText("one");
new Text(composite, SWT.SINGLE).setText("two");
new Combo(composite, SWT.NONE).setText("three");
// init tree
for (int i = 0; i < composite.getChildren().length; i++) {
new TreeItem(tree, SWT.NONE).setText("item " + i);
tree.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
int index = tree.indexOf(tree.getSelection()[0]);
((StackLayout)composite.getLayout()).topControl =
composite.getChildren()[index];
composite.layout();
composite.getChildren()[0];
shell.pack();
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Grant
"Raghava Rao" <raghavadasyam@gmail.com> wrote in message
news:2abd4d154ab01e857f8a38df2e4c45fa$1@www.eclipse.org...
> Hello All,
> other view.
> Raghava
Re: Background application is getting activated. [message #483007 is a reply to message #482926] Sat, 29 August 2009 07:26 Go to previous messageGo to next message
Member
Hello Grant,
Actually i am creating controls in Tabbed properties view.Tabs will be
created based on selection and controls in active tab will be created in
same time.
If Number of tabs have to created more then while changing the selection
back ground application gets activated.
please suggest some solution?
Raghava
Re: Background application is getting activated. [message #483195 is a reply to message #483007] Mon, 31 August 2009 14:20 Go to previous message
I still don't know how this could happen, and without a snippet or plug-in
showing the problem happening I can't offer any suggestions.
Grant
news:d9da88cd5ed341c568f2378eadc417c3$1@www.eclipse.org...
> Hello Grant,
> same time.
> Raghava
Previous Topic:Resize a composite dynamically
Next Topic:Table selection via checkboxes
Current Time: Sun Feb 23 02:33:52 GMT 2020
Powered by FUDForum. Page generated in 0.01954 seconds
