Re: Click on SWTBotToolbarButton - nothing happens [message #483330 is a reply to message #483327] |
Tue, 01 September 2009 07:39 |
Hi Benni,
here is the code :
SWTBotView view =
workbenchbot.viewById(IPageLayout.ID_OUTLINE);
SWTBotToolbarButton toolBarButton =
view.toolbarButton(toolTipText);
toolBarButton.click();
Benjamin Glaser schrieb:
> Hi Aleksey,
> could you show some code?
> I tried it some days ago and it worked for me.
> Benni
Re: Click on SWTBotToolbarButton - nothing happens [message #483655 is a reply to message #483367] |
Wed, 02 September 2009 13:38 |
> Sorry, but I can't replicate the issue.
> SWTBotView view = bot.viewByTitle("title");
> SWTBotToolbarButton toolBarButton = view.toolbarButton("tooltip");
> works fine for me.
> The Tree collaps as expected.
> I used viewbytitle because my testview didn't have an ID so far.
> But I don't think this will change a lot.
> You don't get any exceptions?
> It just don't happens anything?
> Pretty weird...
The run-Method of the action is called, but isChecked() returns always
false ...
As a consequence the implementation assumes that the action is not
enabled and can not add a filter(ViewerFilter) to the tree => no change
in the tree...
Re: Click on SWTBotToolbarButton - nothing happens [message #483687 is a reply to message #483655] |
Wed, 02 September 2009 15:04 |
>> works fine for me.
>> Pretty weird...
> false ...
> in the tree...
.... could be an OS-problem ? (i have ubuntu)
Re: Click on SWTBotToolbarButton - nothing happens [message #483712 is a reply to message #483711] |
Wed, 02 September 2009 16:06 |
>>>> works fine for me.
>>>> Pretty weird...
>>> false ...
>>> change in the tree...
> I don't think it's an OS problem. The SWTBotToolbarButton doesn't set
> the checked status of the button, you should instead use a
> SWTBotToolbarCheckboxButton, like this:
> view.bot().toolbarToggleButton("tooltip");
> I think this should work now. Or maybe not, I don't know if the bot will
> search in the global toolbar or the views toolbar. Give it a try and
> we'll know.
> Another way would be:
> new SWTBotToolbarCheckboxButton(toolBarButton.widget).click();
> I'm pretty sure this one will work, althought it looks clumsy to me...
thank you Pascal, the second way works fine!
FUDForum. Page generated in 0.04270 seconds
