SCA build from source code [message #482481] |
Wed, 26 August 2009 14:04  |
Hi All,
I think instructions to build SCA tools from the link:
http://wiki.eclipse.org/STP/SCA_Component/SCA_Build
has something missing. We are not able to build any features using he
instructions. The key part of the instructions which doesn't work are:
* Open the file site.xml (project org.eclipse.stp.sca.updatesite)
* Select the tab Site Map
* Click Build All
When we click Build All or individual features, nothing happens, not even
the errors? It is not a new issue, its like that for months.
Jamil
Re: SCA build from source code [message #482619 is a reply to message #482611] |
Thu, 27 August 2009 06:26  |
It also works for me.
Does a dialog box appear when you click on Build All?
Do you have warnings, like "Plugin reference org.eclipse.stp.sca....
cannot be resolved", in the Problem View? I updated the wiki page with
the plugins required for a build.
Do you have an old version of SCA Tools installed in your Eclipse? If
yes, can you try with a fresh Galileo install?
Stephane
Vincent Zurczak a écrit :
> Hi Jamil,
> I just tested it and it works.
> Did you check out the features too? On the trunk, they are in a
> directory called "features". Without them, the build cannot work.
> Features are a way to group plug-ins together in a coherent package.
> Vincent.
> Jamil Shaikh a écrit :
>> Hi All,
>> * Click Build All
>> even the errors? It is not a new issue, its like that for months.
>> Thanks,
>> Jamil
Re: SCA build from source code [message #575913 is a reply to message #482481] |
Thu, 27 August 2009 05:39  |
Hi Jamil,
Vincent.
> Hi All,
> * Click Build All
> Jamil
Vincent Zurczak
EBM WebSourcing
+33 (0) 4 38 12 91 72
Re: SCA build from source code [message #575925 is a reply to message #482611] |
Stephane
> Hi Jamil,
> Vincent.
>> Hi All,
>> * Click Build All
>> Thanks,
>> Jamil
FUDForum. Page generated in 0.24896 seconds
