Home » Archived » Service Component Architecture (SCA) Tools » Missing 'Generate Java Skeleton' function
Missing 'Generate Java Skeleton' function [message #482219] Tue, 25 August 2009 13:39 Go to next message
I do not see 'Generate Java Skeleton' function in 2.0.0.200908231911 or
2.0.0.200908021910 weekly loads. Last time we saw the feature was in
2.0.0.200906170711 (June 17th) official load. Any specific reason for
taking that out.
Jamil
Re: Missing 'Generate Java Skeleton' function [message #482399 is a reply to message #482219] Wed, 26 August 2009 08:49 Go to previous messageGo to next message
> taking that out.
> Jamil
Hi Jamil,
Have you associated the SCA nature to the project that contains your
composite file?
If not, select the project in the Navigator view, then right click > SCA
> Add SCA Nature. Normally, the 'Generate Java Skeleton' function
should reappear.
Stephane
Re: Missing 'Generate Java Skeleton' function [message #482400 is a reply to message #482219] Wed, 26 August 2009 08:50 Go to previous messageGo to next message
Hi Jamil,
On Monday, I committed a fix for that.
This is due to recent changes in the SCA nature ID that were not
correctly propagated.
It will be back in next week build. :)
Vincent.
> taking that out.
> Jamil
Vincent Zurczak
EBM WebSourcing
+33 (0) 4 38 12 91 72
Re: Missing 'Generate Java Skeleton' function [message #482406 is a reply to message #482400] Wed, 26 August 2009 09:08 Go to previous messageGo to next message
The next build is already available ;) I made a build 1 hour ago to test
2.0.1
http://build.eclipse.org/stp/committers/sca-tools/2.0.1.2009 08260835/
Stephane
Vincent Zurczak a écrit :
> Hi Jamil,
> Vincent.
>> or 2.0.0.200908021910 weekly loads. Last time we saw the feature was
>> in 2.0.0.200906170711 (June 17th) official load. Any specific reason
>> for taking that out.
>> Thanks,
>> Jamil
Re: Missing 'Generate Java Skeleton' function [message #482480 is a reply to message #482406] Wed, 26 August 2009 13:43 Go to previous messageGo to next message
It still doesn't work. I installed 2.0.1.200908260835. Still do not see
the 'Generate Java Skeleton'; neither SCA > Add SCA Nature.
'SCA Java Project' wizard is broken too. It always gives you error when
you press 'Finish'.
Jamil
Re: Missing 'Generate Java Skeleton' function [message #482599 is a reply to message #482480] Thu, 27 August 2009 04:51 Go to previous messageGo to next message
I fixed the wizards.
But the actions work fine from my workspace.
Stéphane, would it be possible to make another build so that I can test
all of these elements?
Vincent.
> you press 'Finish'.
> Jamil
Vincent Zurczak
EBM WebSourcing
Re: Missing 'Generate Java Skeleton' function [message #482631 is a reply to message #482599] Thu, 27 August 2009 07:42 Go to previous message
Vincent,
Here you go:
http://build.eclipse.org/stp/committers/sca-tools/2.0.1.2009 08270736/
Stephane
> Vincent.
>> Hi,
>> see the 'Generate Java Skeleton'; neither SCA > Add SCA Nature.
>> when you press 'Finish'.
>> Jamil
Re: Missing 'Generate Java Skeleton' function [message #575773 is a reply to message #482219] Wed, 26 August 2009 08:49 Go to previous message
> taking that out.
> Jamil
Hi Jamil,
composite file?
should reappear.
Stephane
Re: Missing 'Generate Java Skeleton' function [message #575798 is a reply to message #482219] Wed, 26 August 2009 08:50 Go to previous message
Hi Jamil,
Vincent.
> taking that out.
> Jamil
Vincent Zurczak
EBM WebSourcing
Re: Missing 'Generate Java Skeleton' function [message #575818 is a reply to message #482400] Wed, 26 August 2009 09:08 Go to previous message
2.0.1
Stephane
> Hi Jamil,
> Vincent.
>> Thanks,
>> Jamil
Re: Missing 'Generate Java Skeleton' function [message #575838 is a reply to message #482406] Wed, 26 August 2009 13:43 Go to previous message
you press 'Finish'.
Jamil
Re: Missing 'Generate Java Skeleton' function [message #575894 is a reply to message #482480] Thu, 27 August 2009 04:51 Go to previous message
Vincent.
> you press 'Finish'.
> Jamil
Vincent Zurczak
EBM WebSourcing
Re: Missing 'Generate Java Skeleton' function [message #575943 is a reply to message #482599] Thu, 27 August 2009 07:42 Go to previous message
Vincent,
Here you go:
Stephane
> Vincent.
>> Hi,
>> Jamil
Previous Topic:SCA build from source code
Next Topic:Re: [stp-dev] STP-SCA Tools not drawing wire lines when reference target uses component URI instead
Current Time: Thu Apr 17 12:15:45 EDT 2025
Powered by FUDForum. Page generated in 0.06239 seconds
