Syntax for Math.pow() funtion in ATL [message #482062] |
Tue, 25 August 2009 09:46  |
I wanted to some mathematical calculation in ATL.
The following code is written in java
double maxDouble = Math.pow(2, 223*8) - 1;
long maxUIntValue = Math.min((long)maxDouble, Long.MAX_VALUE);
I wanted to do same thing in ATL but i don't know how these pow() & min()
functions are defined in ATL.
venkatesh
[ATL] Re: Syntax for Math.pow() funtion in ATL [message #482143 is a reply to message #482062] |
Tue, 25 August 2009 13:10   |
There is no pow() function in ATL, but you can do it using exp() and
log() functions, which are available in ATL, as the min() function.
Here is the list of the numerical functions in ATL:
http://wiki.eclipse.org/ATL/User_Guide#Numerical_data_type_o perations
William
venkatesh a écrit :
> min() functions are defined in ATL.
> Thanks
> venkatesh
Re: [ATL] Re: Syntax for Math.pow() funtion in ATL [message #483587 is a reply to message #482143] |
Wed, 02 September 2009 09:01   |
Hello William ,
I have tried using exp () and log funtion instead of power and min math
funtion in java
if i give let var :Integer= 2.exp()
it's working fine
but i want 2 raise to the power 8 (2^8) how to represent
this in a exp()
there is no example to use this exp() & log() function .
can u please give me some example.
venkatesh
Re: [ATL] Re: Syntax for Math.pow() funtion in ATL [message #483620 is a reply to message #483587] |
Wed, 02 September 2009 11:15   |
This page http://en.wikipedia.org/wiki/Exponentiation#Real_powers
indicates that you can compute pow with exp and log functions:
b^x = exp(x*log(b))
William
venkatesh a écrit :
> Hello William ,
> funtion in java
> if i give let var :Integer= 2.exp() it's working fine
> but i want 2 raise to the power 8 (2^8) how to represent this in a exp()
> Thanks
> venkatesh
FUDForum. Page generated in 0.23941 seconds
